Star trails - Cairds Campsite
Started by Carole, May 18, 2015, 22:55:01
My first attempt at doing star trails.
I was restricted as to where I could place the camera as I wanted to use the laptop and don't yet have Red plexi glass for my 2nd laptop, so I had to place the laptop in the van which meant I could only place the camera close by and trail the cables through the window.
On one side was Fay's glamping POD and car in the foreground obscuring the trees so I imaged the opposite side looking at the trees towards the SW and also looking at the trees that were lit from time to time by passing cars.
My new laptop went to sleep during one image which ended up 20 minutes long, so I presume the laptop didn't tell the camera to stop the capture!!!  (Had to tweak that sub as it was far too pale as I didn't want a 20 minute gap in the trails) and also tweak the laptop so it wouldn't do it again.
Anyway, here it is:
49 x 2min subs 800 iso F5.6 modified Canon 450D
That looks ok Carole, what the red bit?
Do you mean the red on the trees?
That's where the passing cars lit up the trees.
doug
Are the little lines on the trails pauses between different exposures?? Or summat else???
Doug.
nice colourful star trails :-) John
Thanks Mike and John.
QuoteAre the little lines on the trails pauses between different exposures?? Or summat else???
Yes they must be Doug, next time I'll try to make the gap smaller.
That's come out really nicely!
Good colour in there Carole.  Looks like a fairly narrow FOV, what optics did you use ?
Thanks Mark and Robert.
QuoteLooks like a fairly narrow FOV
Yes I thought that.
I used the kit lens that came with the DSLR, 18 - 55mm it says on the lens.  I know absolutely nothing about lenses, so that's about as technical as I get ha ha!
I wasn't using the zoom - at least I don't think I was.
Kenny
Lovely Carole. The colouring has a really nice, almost cartoon-painted effect because of the colouring of the tree.
I had the same question about field of view. It doesn't look like 18mm but that could simply be because the tree dominates the fov, you appear to have the same breadth of stars as my startrail.
Kenny
What app did you use to combine the exposures into a star trail? If you use Startrails or Starstax they both have a fill mode where they will fill in the short gaps between the exposures.
I used Startrails Kenny and used the mode that's not supposed to leave gaps.  I only had 5 sec gaps, what do you normally do?
Those gaps are a bit too big for Startrails to cope with.  In PS rotate a copy very slightly along the trails directions and use the rotated version to fill the gaps.
julian
