Gallery problems
Started by mickw, Apr 15, 2011, 20:51:57
Can't upload to the Gallery.  Goes through the motions and on the final "continue" get critical error message
Erf. Exact text of message would be helpful. I'll have a look.
Usual problems are caused by size and format, so knowing what sort of file you're uploading, and its size (both the actual file size and the dimensions of the image) will also help.
Doh, just read the "how big can files be"
Smaller was the answer  :oops:
As a matter of interest, how big was the one you were trying to upload?
4538 x 3308 @ 6.4 meg
Quote from: mickw on Apr 16, 2011, 09:48:44
...which is about 15 mega pixels, and the software has to expand the image to make the thumbnails...
I'll have to see whether we can let the server use more memory...
Or me resample the image to something less weighty
Failed again.
Got
Successful Uploads
1 uploads were successful.
Please click 'Continue' to add the files to albums.
It just went to blank white screen - url - http://gallery.orpington-astronomy.org.uk/upload.php - which was the same as the previous page
File was jpeg 3000x2368 3.73mb
Hmmm... Sounds like a time-out, perhaps.
Any chance you could email me the problem file so that I can test things, please?
I've flipped the image handling package. I think it may work now (as it worked when I tried...) Please try again.
Mick - why you trying to upload such massive files - can't you resize to something reasonable like 1024X768 or so..
First try I got this -
Critical error
There was an error while processing a database query
Tried again and it worked fine.
Cheers Rick
Quotecan't you resize to something reasonable like 1024X768 or so
I could, but that wouldn't keep breaking the Gallery  :twisted:
I thought the biggest possible was the thing to do  :oops:
Ugh. Sounds like some combination of memory and timing might be the problem, then. Glad it worked this time.
