Sunny Bank Holiday Saturday - 30 April 2022 in WL, CaK and Ha plus animation
Started by Roberto, May 01, 2022, 22:01:52
Hello All
The first few hours of the Bank Holiday were looking up with a very sunny morning and above average seeing.  I managed to image the Sun in White Light, Calcium and Hydrogen Alpha using the 94mm f/7 refractor working at between 2000 and 3000mm EFL.
First, full discs in the three wavelengths.  6 panels of 225 frames each (out of 3000 shots) with exposures ranging from 0.46ms for CaK to 2.5ms for Ha.
Details here:  https://www.astrobin.com/i3ug9n/C/
WL
CaK
Ha
And a 1hr animation (1500 frames every 30 seconds from 10:26 to 11:12UT) of a looping prominence on the limb near AR12995/94.
Details here:  https://www.astrobin.com/l7hrkv/
garrick
Brilliant set of images. The animation is great. You are making me want to get into solar imaging. 😀
GW
Apophis
RedCat51,QHYCCD183,Atik460EXMono,EQ6-R.Altair Astro Tri-Band OSC,BaaderSII1,25" 4.5nm,Ha3.5nm,Oiii3.5nm.
Thank you both!  Observing the Sun (imaging is great but visual is better) since it's so dynamic; particularly in Ha where movement is almost visually real time.
Hugh
Great as usual Roberto - but that animation is something else!
Just stunning :lol:
- Hugh
Already liked them all in Astrobin.
As said above, the animation is anazing.
Thank you Carole, Hugh. I was lucky seeing remained consistent for that long (as well as temperature so focus didn't shift). I wish I had chosen a bigger field of view and stayed for longer but had to run for an appointment...
