M45 taken at Rother Valley DSC
Started by JonH, Sep 17, 2012, 21:59:16
JonH
This is the first image I have had a proper go at processing taken at Rather Valley last weekend.
My processing skills still need a LOT of work!
15 x 5min subs and 8 darks stacked and a little fiddling in DSS then finished off on PS.
Equinox 80ED
NEQ6
Modded Canon 450D
CLS Filter
QHY5 on ST80
Hi JonH,
It's great to see an image from someone new!
You've certainly begun to pull some nebulosity from around the main stars and it's quite possible there is still more that can be done with your data.  I love the star colours - you've preserved them well.  It also looks like your guiding was pretty good.
You won't like me for saying this, but in a dark location like Rother Valley you really didn't need to use the CLS filter for a broadband target like the Pleiades.  There's little light pollution and the the effect of the filter it is to cut the incident light by approximately half - which is bad news.
Anyway, well done - you've made a great start!
JonH
To be honest I still have a LOT to learn, all the gear and no idea springs to mind!
Mostly I'm just fiddling, change that, try this and seeing what happens.
I would have liked to get more time on this as it was still quite low on the horizon when I started but then the clouds rolled in.
Next clear night though and I will defiantly be adding to it (if I can figure out star masks)
Well done Jon, you are coming on in leaps and bounds.  You certainly have the energy, potential skills and enthusiasm to make great headway in imaging.
A suggestion that might improve the image is to make the background less black.  It is always tempting to make the background jet black because we wrongly think that's what the night sky ought to be like.  But some faint nebulosity will also be lost.
Excellent result Jon.
More subs and a gentler hand on the processing would improve matters. The APT help explains framing masks quite well.
JonH
I will bear that in mind when I come to re-process it Mark, I also noticed the darker you make it the more noise becomes apparent. But that might just be my eyes....
I was hoping it would be clear this weekend so can get a good idea what the skies are like where I'm moving too and add to it before the moon gets really bright, but so far the forecast says NO!
Will have to have a read up on that Duncan.
Jon
Nice one Jon, I agree with the other comments - be gentle with it
QuoteThe APT help explains framing masks quite
Has any-one found this of much use?
I find that stars are so faint with the DSLR that I can't see the stars in the framing mask. So for me it only works where there are really bright stars in the FOV.  Shame as it would have been a good tool and one of the reasons I wanted to use APT.
Maybe post processing could be something to consider for a future imaging session.
JonH
Quote
YES! I like this idea!
Yeah I find stars very faint in APT with LiveView. Even with increasing the brightness and gamma it will only show the brightest of stars. Unless you are using a big light bucket scope I doubt there is anything that can be done about that.
Quote from: Carole on Sep 18, 2012, 11:46:47
I use framing masks all the time. Forget live view. Set up a plan taking 1sec exposures at ISO 1600, M size. Use shift click to run it continuously while framing. Easy.
I'll give that a go some time.
Thanks Duncan, info copied and pasted to my useful info folder.
