Curiosity on Mars
Started by Rick, Aug 21, 2012, 09:04:33
Second Cycle of Martian Seasons Completing for Curiosity Rover
NASA's Curiosity Mars rover today completes its second Martian year since landing inside Gale Crater nearly four Earth years ago, which means it has recorded environmental patterns through two full cycles of Martian seasons.
The repetition helps distinguish seasonal effects from sporadic events. For example, a large spike in methane in the local atmosphere during the first southern-hemisphere autumn in Gale Crater was not repeated the second autumn. It was an episodic release, still unexplained. However, the rover's measurements do suggest that much subtler changes in the background methane concentration -- amounts much less than during the spike -- may follow a seasonal pattern. Measurements of temperature, pressure, ultraviolet light reaching the surface and the scant water vapor in the air at Gale Crater show strong, repeated seasonal changes.
Monitoring the modern atmosphere, weather and climate fulfills a Curiosity mission goal supplementing the better-known investigations of conditions billions of years ago. Back then, Gale Crater had lakes and groundwater that could have been good habitats for microbes, if Mars has ever had any. Today, though dry and much less hospitable, environmental factors are still dynamic.
More: http://www.jpl.nasa.gov/news/news.php?feature=6512
NASA Scientists Discover Unexpected Mineral on Mars (Tridymite)
Scientists have discovered an unexpected mineral in a rock sample at Gale Crater on Mars, a finding that may alter our understanding of how the planet evolved.
NASA's Mars Science Laboratory rover, Curiosity, has been exploring sedimentary rocks within Gale Crater since landing in August 2012. In July 2015, on Sol 1060 (the number of Martian days since landing), the rover collected powder drilled from rock at a location named "Buckskin." Analyzing data from an X-ray diffraction instrument on the rover that identifies minerals, scientists detected significant amounts of a silica mineral called tridymite.
This detection was a surprise to the scientists, because tridymite is generally associated with silicic volcanism, which is known on Earth but was not thought to be important or even present on Mars.
More: http://www.jpl.nasa.gov/news/news.php?feature=6540
NASA Weighs Use of Curiosity Rover to Image Potential Mars Water Sites
Ever since it was announced that there may be evidence of liquid water on present-day Mars, NASA scientists have wondered how best to further investigate these long, seasonally changing dark streaks in the hope of finding evidence of life -- past or present -- on the Red Planet.
"It's not as simple as driving a rover to a potential site and taking a scoop of soil," said Jim Green, NASA's director of planetary science. "Not only are these on steep slopes, we need to ensure that planetary protection concerns are met. In other words, how can we search for evidence of life without contaminating the sites with bugs from Earth?"
Pending approval of a mission extension, NASA's Curiosity Mars rover will continue to climb to progressively higher and younger strata on Mount Sharp, investigating how long the ancient, water-rich environments found so far persisted as Mars dried out. Reaching those destinations would bring the rover closer to locations where dark streaks are present on some slopes. On the way, the route would allow the one-ton rover to capture images of the potential water sites from miles away and see if any are the seasonally changing type.
More: http://www.jpl.nasa.gov/news/news.php?feature=6542
Curiosity Rover Findings Point to a More Earth-like Martian Past
Chemicals found in Martian rocks by NASA's Curiosity Mars rover suggest the Red Planet once had more oxygen in its atmosphere than it does now.
Researchers found high levels of manganese oxides by using a laser-firing instrument on the rover. This hint of more oxygen in Mars' early atmosphere adds to other Curiosity findings -- such as evidence about ancient lakes -- revealing how Earth-like our neighboring planet once was.
This research also adds important context to other clues about atmospheric oxygen in Mars' past. The manganese oxides were found in mineral veins within a geological setting the Curiosity mission has placed in a timeline of ancient environmental conditions. From that context, the higher oxygen level can be linked to a time when groundwater was present in the rover's Gale Crater study area.
More: http://www.jpl.nasa.gov/news/news.php?feature=6544
Full-Circle Vista from NASA Mars Rover Curiosity Shows 'Murray Buttes'
Eroded mesas and buttes reminiscent of the U.S. Southwest shape part of the horizon in the latest 360-degree color panorama from NASA's Curiosity Mars rover.
The rover used its Mast Camera (Mastcam) to capture dozens of component images of this scene on Aug. 5, 2016, four years after Curiosity's landing inside Gale Crater.
The visual drama of Murray Buttes along Curiosity's planned route up lower Mount Sharp was anticipated when the site was informally named nearly three years ago to honor Caltech planetary scientist Bruce Murray (1931-2013), a former director of NASA's Jet Propulsion Laboratory, Pasadena, California. JPL manages the Curiosity mission for NASA.
More: http://www.jpl.nasa.gov/news/news.php?feature=6595
NASA's Curiosity Rover Begins Next Mars Chapter
After collecting drilled rock powder in arguably the most scenic landscape yet visited by a Mars rover, NASA's Curiosity mobile laboratory is driving toward uphill destinations as part of its two-year mission extension that commenced Oct. 1.
The destinations include a ridge capped with material rich in the iron-oxide mineral hematite, about a mile-and-a-half (two-and-a-half kilometers) ahead, and an exposure of clay-rich bedrock beyond that.
These are key exploration sites on lower Mount Sharp, which is a layered, Mount-Rainier-size mound where Curiosity is investigating evidence of ancient, water-rich environments that contrast with the harsh, dry conditions on the surface of Mars today.
"We continue to reach higher and younger layers on Mount Sharp," said Curiosity Project Scientist Ashwin Vasavada, of NASA's Jet Propulsion Laboratory, Pasadena, California. "Even after four years of exploring near and on the mountain, it still has the potential to completely surprise us."
More: http://www.jpl.nasa.gov/news/news.php?feature=6632
Curiosity Mars Rover Checks Odd-looking Iron Meteorite
Laser-zapping of a globular, golf-ball-size object on Mars by NASA's Curiosity rover confirms that it is an iron-nickel meteorite fallen from the Red Planet's sky.
Iron-nickel meteorites are a common class of space rocks found on Earth, and previous examples have been seen on Mars, but this one, called "Egg Rock," is the first on Mars examined with a laser-firing spectrometer. To do so, the rover team used Curiosity's Chemistry and Camera (ChemCam) instrument.
Scientists of the Mars Science Laboratory (MSL) project, which operates the rover, first noticed the odd-looking rock in images taken by Curiosity's Mast Camera (Mastcam) at a site the rover reached by an Oct. 27 drive.
More: http://www.jpl.nasa.gov/news/news.php?feature=6667
Curiosity Rover Team Examining New Drill Hiatus
NASA's Curiosity Mars rover is studying its surroundings and monitoring the environment, rather than driving or using its arm for science, while the rover team diagnoses an issue with a motor that moves the rover's drill.
Curiosity is at a site on lower Mount Sharp selected for what would be the mission's seventh sample-collection drilling of 2016. The rover team learned Dec. 1 that Curiosity did not complete the commands for drilling. The rover detected a fault in an early step in which the "drill feed" mechanism did not extend the drill to touch the rock target with the bit.
"We are in the process of defining a set of diagnostic tests to carefully assess the drill feed mechanism. We are using our test rover here on Earth to try out these tests before we run them on Mars," Curiosity Deputy Project Manager Steven Lee, at NASA's Jet Propulsion Laboratory in Pasadena, California, said Monday. "To be cautious, until we run the tests on Curiosity, we want to restrict any dynamic changes that could affect the diagnosis. That means not moving the arm and not driving, which could shake it."
More: http://www.jpl.nasa.gov/news/news.php?feature=6692
Mars Rock-Ingredient Stew Seen as Plus for Habitability
NASA's Curiosity rover is climbing a layered Martian mountain and finding evidence of how ancient lakes and wet underground environments changed, billions of years ago, creating more diverse chemical environments that affected their favorability for microbial life.
Hematite, clay minerals and boron are among the ingredients found to be more abundant in layers farther uphill, compared with lower, older layers examined earlier in the mission. Scientists are discussing what these and other variations tell about conditions under which sediments were initially deposited, and about how groundwater moving later through the accumulated layers altered and transported ingredients.
Effects of this groundwater movement are most evident in mineral veins. The veins formed where cracks in the layers were filled with chemicals that had been dissolved in groundwater. The water with its dissolved contents also interacted with the rock matrix surrounding the veins, altering the chemistry both in the rock and in the water.
More: http://www.jpl.nasa.gov/news/news.php?feature=6700
Mars Rover Curiosity Examines Possible Mud Cracks
Scientists used NASA's Curiosity Mars rover in recent weeks to examine slabs of rock cross-hatched with shallow ridges that likely originated as cracks in drying mud.
"Mud cracks are the most likely scenario here," said Curiosity science team member Nathan Stein. He is a graduate student at Caltech in Pasadena, California, who led the investigation of a site called "Old Soaker," on lower Mount Sharp, Mars.
If this interpretation holds up, these would be the first mud cracks -- technically called desiccation cracks -- confirmed by the Curiosity mission. They would be evidence that the ancient era when these sediments were deposited included some drying after wetter conditions. Curiosity has found evidence of ancient lakes in older, lower-lying rock layers and also in younger mudstone that is above Old Soaker.
More: http://www.jpl.nasa.gov/news/news.php?feature=6721
NASA's Curiosity Rover Sharpens Paradox of Ancient Mars
Mars scientists are wrestling with a problem. Ample evidence says ancient Mars was sometimes wet, with water flowing and pooling on the planet's surface. Yet, the ancient sun was about one-third less warm and climate modelers struggle to produce scenarios that get the surface of Mars warm enough for keeping water unfrozen.
A leading theory is to have a thicker carbon-dioxide atmosphere forming a greenhouse-gas blanket, helping to warm the surface of ancient Mars. However, according to a new analysis of data from NASA's Mars rover Curiosity, Mars had far too little carbon dioxide about 3.5 billion years ago to provide enough greenhouse-effect warming to thaw water ice.
More: http://www.jpl.nasa.gov/news/news.php?feature=6734
Breaks Observed in Mars Curiosity Rover Wheel Treads
A routine check of the aluminum wheels on NASA's Curiosity Mars rover has found two small breaks on the rover's left middle wheel-the latest sign of wear and tear as the rover continues its journey, now approaching the 10-mile (16 kilometer) mark.
The mission's first and second breaks in raised treads, called grousers, appeared in a March 19 image check of the wheels, documenting that these breaks occurred after the last check, on Jan. 27.
"All six wheels have more than enough working lifespan remaining to get the vehicle to all destinations planned for the mission," said Curiosity Project Manager Jim Erickson at NASA's Jet Propulsion Laboratory, Pasadena, California. "While not unexpected, this damage is the first sign that the left middle wheel is nearing a wheel-wear milestone,"
More: https://www.jpl.nasa.gov/news/news.php?feature=6785
Signs of sediment-rich ocean lend direction to Mars life search
If new 3D models of Mars's surface are accurate, we finally possess the most convincing evidence to date that much of the northern hemisphere of Mars was once an ocean.
Scientists at Pennsylvania State University targeted a region known as Aeolis Dorsa, believed to have the densest collection of "fluvial ridges" that indicate the former presence of flowing water on Mars, at least according to 3D maps and models that show similarities in how sediments collect between the red planet and our own.
"Based on these findings, we know there had to have been a period when it was warm enough and the atmosphere was thick enough to support this much liquid water at one time," explains Penn State Assistant Professor of Geosciences and project lead Benjamin Cardenas.
More: https://www.theregister.com/2022/10/31/northern_mars_ocean/
Curiosity gets interplanetary software patch for better driving and more on Mars
NASA has successfully installed a major software update on its venerable Curiosity Mars rover, which has been rolling over the Red Planet's landscape for more than a decade.
The Americans said some 180 changes were included in the update, which was deployed last week. Some were small, NASA said, such as making slight corrections to the messages Curiosity transmits to Earth, making future patch deployments easier, and improving control over the rover's head and arm.
Other updates were major, and included simplifying code that had become a bit bloated over 11 years of piecemeal patches while exploring Mars' Mount Sharp region, along with updates to the rover's movement and steering code.
More: https://www.theregister.com/2023/04/15/nasa_curiosity_patch/
