Curiosity on Mars
Started by Rick, Aug 21, 2012, 09:04:33
Curiosity Makes Its Longest One-Day Drive on Mars
NASA's Mars rover Curiosity drove twice as far on July 21 as on any other day of the mission so far: 109.7 yards (100.3 meters).
The length of the drive took advantage of starting the 340th Martian day, or sol, of the mission from a location with an unusually good view for rover engineers to plan a safe path. In weeks to come, the rover team plans to begin using "autonav" capability for the rover to autonomously navigate a path for itself, which could make such long drives more frequent.
More: http://www.jpl.nasa.gov/news/news.php?release=2013-232
Curiosity team: Massive collision may have killed Red Planet
Sampling suggests Mars lost its atmosphere early in life
Dual tests by instruments on the Curiosity rover, combined with data from the first Viking probes and Mars meteorites that have fallen to Earth, suggests that the Red Planet lost its atmosphere within the first billion years of its history, according to two papers in the latest issue of Science.
"As atmosphere was lost, the signature of the process was embedded in the isotopic ratio," said Paul Mahaffy of NASA Goddard Space Flight Center and the principal investigator for SAM and lead author of one of the two papers about Curiosity.
More from the Register or from the NASA press release.
NASA Rover Gets Movie as a Mars Moon Passes Another
The larger of the two moons of Mars, Phobos, passes directly in front of the other, Deimos, in a new series of sky-watching images from NASA's Mars rover Curiosity.
A video clip assembled from the images is at http://youtu.be/DaVSCmuOJwI .
Large craters on Phobos are clearly visible in these images from the surface of Mars. No previous images from missions on the surface caught one moon eclipsing the other.
More: http://www.jpl.nasa.gov/news/news.php?release=2013-253
NASA Mars Rover Views Eclipse of the Sun by Phobos
Images taken with a telephoto-lens camera on NASA's Mars rover Curiosity catch the larger of Mars' two moons, Phobos, passing directly in front of the sun -- the sharpest images of a solar eclipse ever taken at Mars.
Phobos does not fully cover the sun, as seen from the surface of Mars, so the solar eclipse is what's called a ring, or annular, type. A set of three frames from Curiosity's Mast Camera (Mastcam), taken three seconds apart as Phobos eclipsed the sun, is at http://www.jpl.nasa.gov/spaceimages/details.php?id=PIA17356 .
The images are the first full-resolution frames downlinked to Earth from an Aug. 17, 2013, series. The series may later provide a movie of the eclipse. Curiosity paused during its drive that day to record the sky-watching images.
More: http://www.jpl.nasa.gov/news/news.php?release=2013-263
NASA Rover Inspects Pebbly Rocks at Martian Waypoint
NASA's Mars rover Curiosity has resumed a trek of many months toward its mountain-slope destination, Mount Sharp. The rover used instruments on its arm last week to inspect rocks at its first waypoint along the route inside Gale Crater.
The location, originally chosen on the basis of images taken from NASA's Mars Reconnaissance Orbiter, paid off with investigation of targets that bear evidence of ancient wet environments.
"We examined pebbly sandstone deposited by water flowing over the surface, and veins or fractures in the rock," said Dawn Sumner of University of California, Davis, a Curiosity science team member with a leadership role in planning the stop. "We know the veins are younger than the sandstone because they cut through it, but they appear to be filled with grains like the sandstone."
More: http://www.jpl.nasa.gov/news/news.php?release=2013-288
There is a surprising amount of water bound up in the soil of Mars, according to an analysis done onboard the US space agency's (Nasa) Curiosity rover.
When it heated a small pinch of dirt scooped up from the ground, the most abundant vapour detected was H2O.
Curiosity researcher Laurie Leshin and colleagues tell Science Magazine that Mars' dusty red covering holds about 2% by weight of water.
More:  http://www.bbc.co.uk/news/science-environment-24287207
and a bit More:  Space.com
Curiosity confirms origins of Martian meteorites
Earth's most eminent emissary to Mars has just proven that those rare Martian visitors that sometimes drop in on Earth — a.k.a. Martian meteorites — really are from the Red Planet. A key new measurement of Mars' atmosphere by NASA's Curiosity rover provides the most definitive evidence yet of the origins of Mars meteorites while at the same time providing a way to rule out Martian origins of other meteorites.
The new measurement is a high-precision count of two forms of argon gas—Argon-36 and Argon-38–accomplished by the Sample Analysis at Mars (SAM) instrument on Curiosity. These lighter and heavier forms, or isotopes, of argon exist naturally throughout the solar system. But on Mars the ratio of light to heavy argon is skewed because a lot of that planet's original atmosphere was lost to space, with the lighter form of argon being taken away more readily because it rises to the top of the atmosphere more easily and requires less energy to escape. That's left the Martian atmosphere relatively enriched in the heavier Argon-38.
More: http://news.agu.org/press-release/curiosity-confirms-origins-of-martian-meteorites/
NASA Mars Rover's View of Possible Westward Route
NASA's Curiosity Mars rover reached the edge of a dune on Jan. 30 and photographed the valley on the other side, to aid assessment of whether to cross the dune.
Curiosity is on a southwestward traverse of many months from an area where it found evidence of ancient conditions favorable for microbial life to its long-term science destination on the lower slopes of Mount Sharp. Based on analysis of images taken from orbit by NASA's Mars Reconnaissance Orbiter, a location dubbed "Dingo Gap" was assessed as a possible gateway to a favorable route for the next portion of the traverse.
More: http://www.jpl.nasa.gov/news/news.php?release=2014-033
NASA Mars Orbiter Spies Rover Near Martian Butte
Scientists using NASA's Curiosity Mars rover are eyeing a rock layer surrounding the base of a small butte, called "Mount Remarkable," as a target for investigating with tools on the rover's robotic arm.
The rover works near this butte in an image taken on April 11 by the High Resolution Imaging Science Experiment (HiRISE) camera on NASA's Mars Reconnaissance Orbiter.
More: http://www.jpl.nasa.gov/news/news.php?release=2014-116
Asteroids as Seen From Mars; A Curiosity Rover First
A new image from NASA's Curiosity Mars rover is the first ever from the surface of Mars to show an asteroid, and it shows two: Ceres and Vesta.
These two -- the largest and third-largest bodies in the asteroid belt between Mars and Jupiter -- are the destinations of NASA's Dawn mission. Dawn orbited Vesta in 2011 and 2012, and is on its way to begin orbiting Ceres next year. Ceres is a dwarf planet, as well as an asteroid.
More: http://www.jpl.nasa.gov/news/news.php?release=2014-126
Mercury Passes in Front of the Sun, as Seen From Mars (MSL)
NASA's Curiosity Mars rover has imaged the planet Mercury passing in front of the sun, visible as a faint darkening that moves across the face of the sun.
This is the first transit of the sun by a planet observed from any planet other than Earth, and also the first imaging of Mercury from Mars. Mercury fills only about one-sixth of one pixel as seen from such great distance, so the darkening does not have a distinct shape, but its position follows Mercury's expected path based on orbital calculations.
More: http://www.jpl.nasa.gov/news/news.php?release=2014-183
Curiosity Finds Iron Meteorite on Mars
This rock encountered by NASA's Curiosity Mars rover is an iron meteorite called "Lebanon," similar in shape and luster to iron meteorites found on Mars by the previous generation of rovers, Spirit and Opportunity. Lebanon is about 2 yards or 2 meters wide (left to right, from this angle). The smaller piece in the foreground is called "Lebanon B."
This view combines a series of high-resolution circular images taken by the Remote Micro-Imager (RMI) of Curiosity's Chemistry and Camera (ChemCam) instrument with color and context from rover's Mast Camera (Mastcam). The component images were taken during the 640th Martian day, or sol, of Curiosity's work on Mars (May 25, 2014).
Images and more: http://mars.jpl.nasa.gov/multimedia/images/?ImageID=6433
NASA Rover's Images Show Laser Flash on Martian Rock
Flashes appear on a baseball-size Martian rock in a series of images taken Saturday, July 12 by the Mars Hand Lens Imager (MAHLI) camera on the arm of NASA's Curiosity Mars Rover. The flashes occurred while the rover's Chemistry and Camera (ChemCam) instrument fired multiple laser shots to investigate the rock's composition.
More: http://www.jpl.nasa.gov/news/news.php?release=2014-232
Two Years and Counting on Red Planet
NASA's most advanced roving laboratory on Mars celebrates its second anniversary since landing inside the Red Planet's Gale Crater on Aug. 5, 2012, PDT (Aug. 6, 2012, EDT).
During its first year of operations, the Curiosity rover fulfilled its major science goal of determining whether Mars ever offered environmental conditions favorable for microbial life. Clay-bearing sedimentary rocks on the crater floor in an area called Yellowknife Bay yielded evidence of a lakebed environment billions of years ago that offered fresh water, all of the key elemental ingredients for life, and a chemical source of energy for microbes, if any existed there.
"Before landing, we expected that we would need to drive much farther before answering that habitability question," said Curiosity Project Scientist John Grotzinger of the California Institute of Technology, Pasadena. "We were able to take advantage of landing very close to an ancient streambed and lake. Now we want to learn more about how environmental conditions on Mars evolved, and we know where to go to do that."
During its second year, Curiosity has been driving toward long-term science destinations on lower slopes of Mount Sharp. Those destinations are in an area beginning about 2 miles (3 kilometers) southwest of the rover's current location, but an appetizer outcrop of a base layer of the mountain lies much closer -- less than one-third of a mile (500 meters) from Curiosity. The rover team is calling the outcrop "Pahrump Hills."
More: http://www.jpl.nasa.gov/news/news.php?release=2014-262
Curiosity Mars Rover Finds Mineral Match
Reddish rock powder from the first hole drilled into a Martian mountain by NASA's Curiosity rover has yielded the mission's first confirmation of a mineral mapped from orbit.
"This connects us with the mineral identifications from orbit, which can now help guide our investigations as we climb the slope and test hypotheses derived from the orbital mapping," said Curiosity Project Scientist John Grotzinger, of the California Institute of Technology in Pasadena.
Curiosity collected the powder by drilling into a rock outcrop at the base of Mount Sharp in late September. The robotic arm delivered a pinch of the sample to the Chemistry and Mineralogy (CheMin) instrument inside the rover. This sample, from a target called "Confidence Hills" within the "Pahrump Hills" outcrop, contained much more hematite than any rock or soil sample previously analyzed by CheMin during the two-year-old mission. Hematite is an iron-oxide mineral that gives clues about ancient environmental conditions from when it formed.
More: http://www.jpl.nasa.gov/news/news.php?feature=4361
