Curiosity on Mars
Started by Rick, Aug 21, 2012, 09:04:33
Curiosity Rover Finds Clues to How Water Helped Shape Martian Landscape
Observations by NASA's Curiosity Rover indicate Mars' Mount Sharp was built by sediments deposited in a large lake bed over tens of millions of years.
This interpretation of Curiosity's finds in Gale Crater suggests ancient Mars maintained a climate that could have produced long-lasting lakes at many locations on the Red Planet.
"If our hypothesis for Mount Sharp holds up, it challenges the notion that warm and wet conditions were transient, local, or only underground on Mars," said Ashwin Vasavada, Curiosity deputy project scientist at NASA's Jet Propulsion Laboratory in Pasadena. "A more radical explanation is that Mars' ancient, thicker atmosphere raised temperatures above freezing globally, but so far we don't know how the atmosphere did that."
Why this layered mountain sits in a crater has been a challenging question for researchers. Mount Sharp stands about 3 miles (5 kilometers) tall, its lower flanks exposing hundreds of rock layers. The rock layers – alternating between lake, river and wind deposits -- bear witness to the repeated filling and evaporation of a Martian lake much larger and longer-lasting than any previously examined close-up.
"We are making headway in solving the mystery of Mount Sharp," said Curiosity Project Scientist John Grotzinger of the California Institute of Technology in Pasadena, California. "Where there's now a mountain, there may have once been a series of lakes."
More from NASA
NASA Rover Finds Active and Ancient Organic Chemistry on Mars
NASA's Mars Curiosity rover has measured a tenfold spike in methane, an organic chemical, in the atmosphere around it and detected other organic molecules in a rock-powder sample collected by the robotic laboratory's drill.
"This temporary increase in methane -- sharply up and then back down -- tells us there must be some relatively localized source," said Sushil Atreya of the University of Michigan, Ann Arbor, a member of the Curiosity rover science team. "There are many possible sources, biological or non-biological, such as interaction of water and rock."
Researchers used Curiosity's onboard Sample Analysis at Mars (SAM) laboratory a dozen times in a 20-month period to sniff methane in the atmosphere. During two of those months, in late 2013 and early 2014, four measurements averaged seven parts per billion. Before and after that, readings averaged only one-tenth that level.
More: http://www.jpl.nasa.gov/news/news.php?feature=4413
Curiosity Analyzing Sample of Martian Mountain
The second bite of a Martian mountain taken by NASA's Curiosity Mars rover hints at long-ago effects of water that was more acidic than any evidenced in the rover's first taste of Mount Sharp, a layered rock record of ancient Martian environments.
The rover used a new, low-percussion-level drilling technique to collect sample powder last week from a rock target called "Mojave 2."
More:http://www.jpl.nasa.gov/news/news.php?feature=4477
Curiosity Rover Finds Biologically Useful Nitrogen on Mars
A team using the Sample Analysis at Mars (SAM) instrument suite aboard NASA's Curiosity rover has made the first detection of nitrogen on the surface of Mars from release during heating of Martian sediments.
The nitrogen was detected in the form of nitric oxide, and could be released from the breakdown of nitrates during heating. Nitrates are a class of molecules that contain nitrogen in a form that can be used by living organisms. The discovery adds to the evidence that ancient Mars was habitable for life.
Nitrogen is essential for all known forms of life, since it is used in the building blocks of larger molecules like DNA and RNA, which encode the genetic instructions for life, and proteins, which are used to build structures like hair and nails, and to speed up or regulate chemical reactions.
More: http://www.jpl.nasa.gov/news/news.php?feature=4516
Curiosity Rover Making Tracks and Observations
NASA's Curiosity Mars rover is continuing science observations while on the move this month. On April 16, the mission passed 10 kilometers (6.214 miles) of total driving since its 2012 landing, including about a fifth of a mile (310 meters) so far this month.
The rover is trekking through a series of shallow valleys between the "Pahrump Hills" outcrop, which it investigated for six months, and the next science destination, "Logan Pass," which is still about 200 yards, or meters, ahead toward the southwest.
"We've not only been making tracks, but also making important observations to characterize rocks we're passing, and some farther to the south at selected viewpoints," said John Grant of the National Air and Space Museum, Washington. Grant is a Curiosity science team member who has been the team's long-term planner in recent days.
More: http://www.jpl.nasa.gov/news/news.php?feature=4556
Quick Detour by NASA Mars Rover Checks Ancient Valley
This April 16, 2015, panorama from the Mast Camera on NASA's Curiosity Mars rover shows a detailed view toward two areas on lower Mount Sharp chosen for close-up inspection in subsequent weeks: "Mount Shields" and "Logan Pass." Credit: NASA/JPL-Caltech/MSSS
› Full image and caption
Fast Facts:
› Rover inspected a site where a valley was cut into bedrock, then refilled.
› A site of that type had not been seen previously on Mars.
Researchers slightly detoured NASA's Curiosity Mars rover from the mission's planned path in recent days for a closer look at a hillside site where an ancient valley had been carved out and refilled.
The rover made observations and measurements there to address questions about how the channel formed and filled. Then it resumed driving up Mount Sharp, where the mission is studying the rock layers. The layers reveal chapters in how environmental conditions and the potential to support microbial life changed in Mars' early history.
Two new panoramas of stitched-together telephoto images from Curiosity's Mast Camera (Mastcam) present the increasingly hilly region the rover has been investigating, and more distant portions of Mount Sharp. These large images are online, with pan and zoom controls for exploring them, at:
http://mars.nasa.gov/msl/multimedia/deepzoom/PIA19397
http://mars.nasa.gov/msl/multimedia/deepzoom/PIA19398
Curiosity has been exploring on Mars since 2012.
More: http://www.jpl.nasa.gov/news/news.php?feature=4579
NASA's Curiosity Rover Adjusts Route Up Martian Mountain
NASA's Curiosity Mars rover climbed a hill Thursday to approach an alternative site for investigating a geological boundary, after a comparable site proved hard to reach.
The drive of about 72 feet (22 meters) up slopes as steep as 21 degrees brought Curiosity close to a target area where two distinctive types of bedrock meet. The rover science team wants to examine an outcrop that contains the contact between the pale rock unit the mission analyzed lower on Mount Sharp and a darker, bedded rock unit that the mission has not yet examined up close.
Two weeks ago, Curiosity was headed for a comparable geological contact farther south. Foiled by slippery slopes on the way there, the team rerouted the vehicle and chose a westward path.The mission's strategic planning keeps multiple route options open to deal with such situations.
More: http://www.jpl.nasa.gov/news/news.php?feature=4596
Mars Rover's Laser-Zapping Instrument Gets Sharper Vision
Tests on Mars have confirmed success of a repair to the autonomous focusing capability of the Chemistry and Camera (ChemCam) instrument on NASA's Curiosity Mars rover.
This instrument provides information about the chemical composition of targets by zapping them with laser pulses and taking spectrometer readings of the induced sparks. It also takes detailed images through a telescope.
Work by the instrument's team members at Los Alamos National Laboratory in New Mexico and in France has yielded an alternative auto-focus method following loss of use of a small laser that served for focusing the instrument during Curiosity's first two years on Mars.
"Without this laser rangefinder, the ChemCam instrument was somewhat blind," said Roger Wiens, ChemCam principal investigator at Los Alamos. "The main laser that creates flashes of plasma when it analyzes rocks and soils up to 25 feet [7.6 meters] from the rover was not affected, but the laser analyses only work when the telescope projecting the laser light to the target is in focus."
More: http://www.jpl.nasa.gov/news/news.php?feature=4597
Curiosity celebrates 1000 sols on Mars
Shortly before Mars' June 2015 conjunction, the Curiosity Rover celebrated 1000 sols on the red planet. After its August 5, 2012 landing, Curiosity's 1000th sol or martian day on the surface corresponded to planet Earth's calendar date May 31, 2015.
APOD
NASA's Curiosity Mars Rover Tracks Sunspots
While busily investigating bedrock types on Mars' Mount Sharp and preparing for a drill test, NASA's Curiosity Mars rover has also been looking up frequently to monitor sunspots on the face of the sun that is turned away from Earth.
Large sunspots are evident in views from Curiosity's Mast Camera (Mastcam). Scientists temporarily have no other resource providing views of the sun from the opposite side of the solar system from Earth. The sun completes a rotation about once a month -- faster near its equator than near its poles. Information about sunspots that develop before they rotate into view of Earth and Earth-orbiting spacecraft is helpful in predicting space-weather effects of solar emissions related to sunspots.
More: http://www.jpl.nasa.gov/news/news.php?feature=4657
New Online Exploring Tools Bring NASA's Journey to Mars to New Generation
On the three-year anniversary of the Mars landing of NASA's Curiosity rover, NASA is unveiling two new online tools that open the mysterious terrain of the Red Planet to a new generation of explorers, inviting the public to help with its journey to Mars.
Mars Trek is a free, Web-based application that provides high-quality, detailed visualizations of the planet using real data from 50 years of NASA exploration and allowing astronomers, citizen scientists and students to study the Red Planet's features.
Experience Curiosity allows viewers to journey along with the one-ton rover on its Martian expeditions. The program simulates Mars in 3-D based on actual data from Curiosity and NASA's Mars Reconnaissance Orbiter (MRO), giving users first-hand experience in a day in the life of a Mars rover.
More: http://www.jpl.nasa.gov/news/news.php?feature=4680
Mars Trek: http://marstrek.jpl.nasa.gov/
Journey to Mars: https://www.nasa.gov/topics/journeytomars
Experience Curiosity: http://eyes.nasa.gov/curiosity/
NASA Mars Rover Moves Onward After 'Marias Pass' Studies
NASA's Curiosity Mars rover is driving toward the southwest after departing a region where for several weeks it investigated a geological contact zone and rocks that are unexpectedly high in silica and hydrogen content. The hydrogen indicates water bound to minerals in the ground.
The rover finished activities in Marias Pass on Aug. 12 and headed onward up Mount Sharp, the layered mountain it reached in September 2014. In drives on Aug. 12, 13, 14 and 18, it progressed 433 feet (132 meters), bringing Curiosity's total odometry since its August 2012 landing to 6.9 miles (11.1 kilometers).
Curiosity is carrying with it some of the sample powder drilled from Buckskin. The rover's internal laboratories are analyzing the material. The mission's science team members seek to understand why this area bears rocks with significantly higher levels of silica and hydrogen than other areas the rover has traversed.
More: http://www.jpl.nasa.gov/news/news.php?feature=4690
Upgrade Helps NASA Study Mineral Veins on Mars
Scientists now have a better understanding about a site with the most chemically diverse mineral veins NASA's Curiosity rover has examined on Mars, thanks in part to a valuable new resource scientists used in analyzing data from the rover.
Curiosity examined bright and dark mineral veins in March 2015 at a site called "Garden City," where some veins protrude as high as two finger widths above the eroding bedrock in which they formed.
The diverse composition of the crisscrossing veins points to multiple episodes of water moving through fractures in the bedrock when it was buried. During some wet periods, water carried different dissolved substances than during other wet periods. When conditions dried, fluids left clues behind that scientists are now analyzing for insights into how ancient environmental conditions changed over time.
More: http://www.jpl.nasa.gov/news/news.php?feature=4766
Sandy Selfie Sent from NASA Mars Rover
The latest self-portrait from NASA's Curiosity Mars rover shows the car-size mobile laboratory beside a dark dune where it has been scooping and sieving samples of sand.
The new selfie combines 57 images taken by the Mars Hand Lens Imager (MAHLI) camera at the end of Curiosity's arm on Jan. 19. It is online at
http://www.jpl.nasa.gov/spaceimages/details.php?id=PIA20316
The rover has been investigating a group of active sand dunes for two months, studying how the wind moves and sorts sand particles on Mars. The site is part of Bagnold Dune Field, which lines the northwestern flank of Mars' Mount Sharp.
More: http://www.jpl.nasa.gov/news/news.php?feature=4835
Curiosity Mars Rover Crosses Rugged Plateau
NASA's Curiosity Mars rover has nearly finished crossing a stretch of the most rugged and difficult-to-navigate terrain encountered during the mission's 44 months on Mars.
The rover climbed onto the "Naukluft Plateau" of lower Mount Sharp in early March after spending several weeks investigating sand dunes. The plateau's sandstone bedrock has been carved by eons of wind erosion into ridges and knobs. The path of about a quarter mile (400 meters) westward across it is taking Curiosity toward smoother surfaces leading to geological layers of scientific interest farther uphill.
The roughness of the terrain on the plateau raised concern that driving on it could be especially damaging to Curiosity's wheels, as was terrain Curiosity crossed before reaching the base of Mount Sharp. Holes and tears in the rover's aluminum wheels became noticeable in 2013. The rover team responded by adjusting the long-term traverse route, revising how local terrain is assessed and refining how drives are planned. Extensive Earth-based testing provided insight into wheel longevity.
More: http://www.jpl.nasa.gov/news/news.php?feature=6452
