Gerd Neumann light panel
Started by Fay, May 15, 2012, 09:25:37
The inverter that came with the above, the cable has snapped & I don't think anything can be done to repair it as the wires are in a solid block. does anyone know if I can buy one just anywhere or does it have to be from the light panel company?
Is the wire still OK at the light panel ?
Any inverter should do but it all depends what voltage the panel is and what voltage you have to plug it into.
Give Ian King a ring
yes the bit into the panel is ok
