M101 Luminance
Started by Rocket Pooch, Apr 07, 2011, 19:52:22
6x15 minute subs, flats applied, I have RGB, just thinking about processing it, but I'm well chufed with this.
M101-Luminence by chrissuddell, on Flickr
That looks really nice Chris with plenty of detail.
I bet you are chuffed - that looks superb & massive - the galaxy near on takes up the whole 3000 pixel frame. Tons of detail & very smooth.
Impressed - John
PhilB
Impressive. There's a fantastic amount of detail, you've every right to be chuffed.
Very good image, that.  What focal length are you using?
It would need a large number of subs to start bringing detail to those very faint outer arms.
Hi Mark,
I think its about 1.5 meters, I need to meausre the FR to chip distance to work it out properly.  But its an SCT so that will not be too accurate..
Hi Chris,
If you get someone to solve the image in Maxim 5.x it will give you the size of the field of view and you can work out the focal length from that. I did it once for my set-up and with my Baader Telecompressor, DSLR at prime focus, the focal length came out to about 1250mm. I must have done the same with an image with no FR in the train and then worked out the ratio of the FoVs. I assumed that the base focal length was 2000mm, but that depends on where your mirror is in the OTA (8" SCT of course). There is probably an accurate way of using this information to work out the actual focal length for a given FoV with a DSLR at prime focus.
Duncan
Looking very nice indeed, Chris
Quote from: Rocket Pooch on Apr 08, 2011, 07:49:57
Hi Mark,
I can plate solve to get you the f/l in MaximDL when I get home if you like ?
Real nice image Chris.
very nice, loads of detail in the arms
For some reason the image on the forum looks blocky and horrible, but the full size on Flikr is perfect (on this machine anyway) :-?
Quote from: mickw on Apr 12, 2011, 08:49:57For some reason the image on the forum looks blocky and horrible, but the full size on Flikr is perfect (on this machine anyway) :-?
Looks fine here. Is it a progressive JPEG? Maybe your machine gave up half way through?
Quote from: mickw
I have the same problem at home with "blocky images".  At work it looks fine but at home it looks blocky and horrible.  I strongly suspect the reason is that, in my case, I am using mobile broadband at home (until my "proper" broadband is installed).  I bet there is some kind of "bandwidth optimiser" that doesn't download the highest resolution of a progressively encoded image.
BTW the blockiness is just as bad using either IE or Firefox browsers.
Quote from: MarkS on Apr 12, 2011, 14:21:56
Weird. Makes me wonder whether the server is doing something different when it thinks it's talking to a mobile phone...
It's not the server its bandwiidth Nazi's pn mobile devices then de-res images so all the little iPhone people don't swamp the mobile internet with images.
Look fine here, but hey I have the origional..
