Quick test of Pentax 6x7 lens
Started by Rocket Pooch, Aug 23, 2010, 22:49:46
I'm going to resist commenting on that  :o
What wi........................
On second thoughts  :o
PhilB
Fay, there's nothing like a decent pair of stilsons:
http://www.screwfix.com/prods/27604/Hand-Tools/Pipe-Wrenches/Record-Stilson-14-355mm-?cm_mmc=GoogleBase-_-Datafeed-_-Hand%20Tools-_-Record%20Stilson%2014%22%20%28355mm%29
But, seriously, go easy with the spanners or what have you, they can make a complete mess of things very quickly.
I have 14" stilsons and a mole wrench you can borrow if that helps, be careful though I don't want them all bent or broken.
The filter wheel is sitting on ice at the moment, next to the rubber glove!!!!!!!!! Waiting for my tool delivery.......hope it's quick
Fay,
Does the new tool/s vibrate?  You might need something that vibrates to get it off.
You must be nearly ecstatic at the prospect !!!
Sorry that was supposed to be addressed to Fay  ;)
Well the ice & the rubber glove did the trick.........this time!
Quote from: Fay on Aug 24, 2010, 22:21:33
something to add to the "things to do before I die" list
Fay,
Have you tried lubricated the threads?  It might prevent it becoming quite to locked next time.
I think black boot polish, a small touch, or silicon grease works, but an absolute minimum, and dont get it on the optics.
