Chompa Chompa Chompa ... well ok NGC281
Started by RobertM, Aug 29, 2008, 19:10:31
I know, not a very good pacman impression ...
Pacman Nebula NGC281 from 24th Aug.
Posted via Flickr, 90 minutes Ha in 5 min subs with the Sky 90 and SXV-H9/Astronomik 13nm Ha filter.
Other sizes here : http://www.flickr.com/photos/29673723@N04/2809405970/sizes/l/
Robert that looks a lot better - looks like you brightened up the neb...
that's a great shot again - can't believe resultrs you are getting unguided....
Fantastic! was this taken somewhere really dark? the contrast is lovely!
Taken from sunny downtown Orpington so no not a dark site and there was high cloud but you have to take it when you can get it !
That's just amazing then, love how flat the field is all the way across
Yes, you are getting some really good images, Robert. Such short subs as well.
I like this one, had not noticed it is quite a nice subject, before.
Must try it out.
Fay, Shorter subs = less problems and since I nearly always catch a 747 before midnight it helps.  Also with the subjects being nearer the pole PA is not so critical so I can get away with unguided.  Both Cepheus and Cassiopea have some really lovely nebulae and now is a good time ... might try another one with the DSLR tonight - clear did you say ?  Mind you, your record recently is worse than the BBC so I'm not holding out much hope :(
Is there a certain instance when you use OIII filter? Or do you use it when you fancy?
Fay, I have never used an OIII filter but most if not all emission nebulae emit some light due to ionized Oxygen.  The band is generally not as bright as Ha - Hydrogen is the most abundant element in the universe so there's more of it about to be ionized.  I would say in answer that you need to give it a try on something you know has strong OIII emissions.  The Pacman nebula will be my first attempt.
Hope that helps
Took 80 minutes of OIII and synthesised the green channel with Ha using Noels tools.  This is my first attempt with the OIII filter and didn't get the camera lined up between nights - doh !  Will also have to do some extra noise processing and it's going to need a whole lot more subs...
18 x 5 min Ha unguided
8 x 10 min OIII guided
Ha -> Red
OIII -> Blue
Synthesised -> Green
Robert,
That is looking very good.  The detail is excellent, there are some lovely variations in nebulosity and the "guiding" is spot on.  Very nicely processed.
Quoteand the "guiding" is spot on
Mark believe it or not I don't think Robert guides????
Robert - that image is looking fantastic - that is one of the best Pacman neb's I have seen - the colours are fantastic - not too 'overpowering' - All I can say is very expertly processed...
Quote from: JohnP
That's why I put "guiding" in quotes ...
