NGC6888 Jellyfish/Brain false colour HaO3 & Inverted Ha 75% actual size
Started by Rocket Pooch, Jun 12, 2008, 18:18:23
Very nice Chris. Do you mean The Crescent?
Have you rung Ian King yet?
ok we made up a name for it.
yes i did call him he was very halpfull as usual, hence the results
Having looked up the Jellyfish, it reminded me that it is one I meant to do, it is so complex also I like it in mono.
Have to wait for it to come around again.
Quote from: Fay
Having looked up the Jellyfish, it reminded me that it is one I meant to do ...
I looked up Jellyfish in Microsoft's Worldwide Telescope but it didn't find it ...
I made it up!!!!!  I think it looks like the cauliflower nebula...
Update, got notification from Atik the cooling was off on this image due to a bug in the AA Driver, so this image was not cooled!
Thank God for that, Chris. Waiting to see the next image now!!!!!!!
I have now got the test images from one of the guys who wrote the Artemis capture software, he has no hot pixels unlike me, so I now need to cause hell.
Pissed of from Mottingham...
So, Chris, are you saying that your images will not improve when the cooler is put on?
So, that was not the problem?
Hot pixels mean those pixels are dead and appear permanently white on your image no matter what you do. The higher the quality of CCD the lower the number of hot pixels. Ideally you want none, though 'drizzling' inbetween frames (i.e. having the mount shuffle the image around a few pixels) will mean that you can average them out using a Sigma stack as each sub will have the hot pixel in a different part of the frame relative to your image so that after alignment they will not be in the same location as previous frames.
I understand that Mike but out of interest I took some 5min & 10min darks with my atik 16ic camera. There are quite a few hot pixels but they are only at the 1000-2000 ADU level not 65000 so when I stack & process my images they just disappear into the background/ signal. That is why I don't need to take darks. I'm wondering if I turned my cooler off would those hot pixels go to the 65000 level????
I don't think it would make any difference. I think a dead pixel gives out a set signal.
