IC 1396 CCD and DSLR comparison
Started by ApophisAstros, Oct 06, 2018, 19:19:14
Imaging telescope or lens:SkyWatcher 120ED Imaging System for Canon DSLR Cameras
Imaging camera:Canon 1000D modified DSLR
Focal reducer:Skywatcher 0.85x Focal Reducer/Corrector for Evostar-120ED
Software:DeepSkyStacker x64 by Luc Coiffier, Tony Cook, David C. Partridge Deepsky Stacker 4.1 64bit,  Astro Photography Tool,  ADOBE PHOTOSHOP CC
Accessory:QHYCCD PoleMaster
Resolution: 3906x2602
Dates: May 19, 2018
Frames: 44x300" Dithered
Integration: 3.7 hours
Avg. Moon age: 4.50 days
Avg. Moon phase: 21.21%
Astrometry.net job: 2287273
RA center: 324.867 degrees
DEC center: 57.488 degrees
Pixel scale: 1.494 arcsec/pixel
Orientation: 264.262 degrees
Field radius: 0.974 degrees
Locations: Home, Worthing, West Sussex, United Kingdom
Data source: Backyard
Imaging camera:ZWO ASI183MM Monochrome 4/3" CMOS USB3.0 Deep Sky Imager Camera
Software:DeepSkyStacker x64 by Luc Coiffier, Tony Cook, David C. Partridge Deepsky Stacker 4.1 64bit,  Astro Photography Tool,  ADOBE PHOTOSHOP CS2 version 9
Filters:ZWO CCD LRGB Filter-Set 36mm,  zwo EFW 7-position Filter Wheel for 36mm Unmounted Filters
Resolution: 5488x3668
Dates: Oct. 4, 2018
Frames: 15x600s Luminance(gain53) , 4x300s of each RGB(gain60) Dithered
Integration: 2.5 hours
Avg. Moon age: 24.41 days
Avg. Moon phase: 26.90%
Astrometry.net job: 2290897
RA center: 324.217 degrees
DEC center: 57.492 degrees
Pixel scale: 0.628 arcsec/pixel
Orientation: 283.514 degrees
Field radius: 0.576 degrees
An interesting comparison!  Were the sky conditions similar for each image because the result is a bit counterintuitive.
To be honest I prefer the top image - the one that you've labelled "Canon 1000D modified DSLR".  Did you use the correct combination for the Bayer matrix because the H-alpha has come out green.  Or did you change the colour scheme later?  I quite like the effect though!
The star colours are a bit weird in the bottom one (labelled "ZWO ASI183MM ").  But I'm sure you can stretch the data a bit more, to match the dynamic range from the Canon.
You've got the main feature centred much better in the ZWO version, but to be honest there looks to be better colour balance in the DSLR version.  This is all probably down to processing.
Yes DSLR version is the better colour
I did think that as well ,
