Solar Image With A Baader Filter
Started by ApophisAstros, May 21, 2017, 20:42:17
http://gallery.orpington-astronomy.org.uk/albums/userpics/10062/Single__0149_ISO200_1-2000s__41Cresized.jpg
First time with Eqmod aswell connected to laptop. Stellarium mostly. Tracking was spot on with a few fine adjustments.
One single shot , 1/2000sec ,ISO 200
It shows todays two sunspots around the centre if you zoom in , 2656 and 2658 according to this from Spacewether.com
Skywatcher EVOSTAR-120ED DS-PRO120MM (4.75") F/900 ED APOCHROMATIC REFRACTOR  with .8 x FOCAL REDUCER
Canon EOS 750D Baader Modified for daylight and astronomical use. 24.2MP CMOS sensor DIGIC6 processor New development of 7560 pixel RGB + IR photometry sensor AF 19 points Hybrid CMOS AF III Dynamic tracking continuous shooting in live view
doug
Your photo`s are too big to go onto my OAS report, Roger. Try and make them smaller; it makes it easier to copy and paste them into the panes.
Doug.
Doug, click on the "too big image" and it will come up with a box around it.  Take one corner of the box and drag it towards the opposite corner in stages.  Eventually the image should fit the slide.
Quote from: doug on May 22, 2017, 10:04:06Try and make them smaller; it makes it easier to copy and paste them into the panes.
I hadn't noticed before that it was on the O.A.S. Gallery, or I'd have pointed out that the gallery makes a suitably-sized smaller image automatically. Just look for the image with a filename beginning "normal_". It's the one you see wheh you look at the gallery page for the image with its details, and it's a good size for linking in the forum, too.
