Jupiter, Europa and GRS 2015-04-08- 21:02.2 Manche
Started by The Thing, Apr 09, 2015, 14:16:48
Image date, time and location:   2015-04-08- 21:02.2 Manche
Telescope aperture and focal ratio:   LX90 8" f25 5025mm
Camera and filters used:           QHY5LII Colour, PierroAstro ADC, Moonfish 2x Ed barlow.
Processing applied:                   This is 30 AVIs (500 frames/90s with 20s intervals) processed into 30 PNG files via AutoStakkert2! and Registax 6 then for the second picture, measured, derotated and compiled into the final image with WinJUPOS.
Europa is just above and in front (left) of the Great Red Spot.
A bit over-processed to show detail :)
Amazing Duncan, as you say a bit overprocessed, but excellent nevertheless.
Kenny
Quote from: The Thing on Apr 09, 2015, 14:16:48
Only very slightly. It does show a lot more detail. Would be interesting to see what an animation of that would look like.
Fantastic capture again.
is that blue sky you can see through the gaps in the clouds in the middle band????
roger
Quote from: Kenny on Apr 09, 2015, 16:26:10
It has ALL the animation data, so there are no more frames!
well done Duncan, you are getting quite the expert on Jupiter!
RachelC
Kenny
Quote from: The Thing on Apr 09, 2015, 20:06:52
Ah. I understand now. I need some help figuring out WinJupos! :)
Definitely getting better ;)
I agree that you're pushing the processing a bit but there is a fair amount of detail to pull out so I think that's justified - a superb result !
julian
