Comet Lovejoy from Bromley
Started by Carole, Jan 16, 2015, 20:13:01
This is my first image of a comet.
12 x 1min subs, stacked in DSS.
Modified Canon 450D
I'd like to try it again another night with a CCD camera.
I was guiding on the comet and also did some 2 min subs, but when I tried to stack them in comet mode so the stars trailed they all but disappeared they were so faint.
That's great Carole. What lens/scope were you using?
ive been looking for it but cant find it!!  thats good Carole
Nice picture Carole.
The colour looks good and you've definitely got some tail there.
Is it really your first image of a comet?
QuoteIt's your first ever image of a comet?
I did attempt to image comet Jaques last year but it was too faint to guide on, and gave up.
QuoteWhat lens/scope were you using
ED120 and DSLR (this is full frame BTW)
Quoteive been looking for it but cant find it!!
I entered the co-ordinates in manually using this website:
http://www.livecometdata.com/comets/c2014-q2-comet-lovejoy/
I've stacked the 2 min subs manually as the stars were almost invisible with DSS, and Registax couldn't latch onto the comet, so I did it manually in Photoshop.  Doesn't show any more of the tail but does show the movement of the comet.
Kenny
good carole, i will have to put co ordinates in next time, was still getting to grips with the DSLR again, cant believe how quick the batteries were going!! had them on a conveyor belt, charging!!
i was up to my neck and eyes in mud and I stuck to my seat in the frost!!!!
Quotewas still getting to grips with the DSLR again
Same here, it's a long time since I used it, apart from the widefield stuff a few days ago.
Quotecant believe how quick the batteries were going!!
I bought myself a cabled battery it was about £23 from Astronomiser, plugs into the 12V system.  No need to worry about charging up batteries or checking if they are going flat.
I know what you mean about the weather though, nearly froze my wotsits off when I did this image.  But at least I am not sitting directly out in it.
Quote from: Fay
Are you using EQMOD? If so just, just load up the comet's ephemerides in the planetarium software and you'll slew straight to it every day!
You can also enter it in the handset of the Synscan, which is what I did.
#11
Quote from: MarkS on Jan 17, 2015, 09:57:06
Quote from: Fay
And you can load MPC data direct into EQMOD to set a custom slew rate for the comet track. EQMOD can also slew to the object/comet once you have done this. RT(f)M
EQASCOM on YouTube: Custom Tracking via MPC ephemeris data
I attempted to create a movie, I've only done this once before with the aurora.
It's a bit slow.  I guided on the comet so it looks like the stars are moving instead of the comet and slide 8 is a bit dodgy.
This comprises of 12 x 1min subs and 13 x 2min subs with roughly a 5min gap in between except when i changed the length of the subs which took longer, totalling around 38 minutes approx overall.
Any-one got a good download link to Gif, I tried to download one, but it seemed a bit dodgy, so I went for Microsoft Movie maker which came up on the PC.
http://youtu.be/8MurIcwzqjE
Kenny
This video is private Carole.
It's supposed to be available to any-one I give the link to.  I've changed the settings to public, can you try again please.
