Author Topic: Re: First attempt at starfields - Orion & Lovejoy  (Read 2560 times)
Canadian Roger
  • Non-OAS
  • Nebula Class
« on: Jan 04, 2015, 06:58:45 »
In the middle, down near the horizon, to the left of the blue letters I added (and not particularly well)...is that Comet Lovejoy?
It's been very cloudy here, and the only clear nights we've had in the last three weeks are when I;ve been working.
Could someone who's possibly seen this comet confirm, please?
MarkH
  • Star Class
Re: Re: First attempt at starfields - Orion & Lovejoy
« Reply #1 on: Jan 04, 2015, 10:19:32 »
It's much closer to Rigel at the moment Roger about the same distance away from the belt in the opposite direction, so it depends when the exposure was taken.
« Reply #2 on: Jan 04, 2015, 11:33:22 »
Hi Roger,
As MarkH said, timing is everything.  When did you take the image?  If it was taken on the evening of 28th Dec then it is quite possibly the comet and worth doing a more detailed check.  If it was taken on any other date then it is definitely not the comet because it noticeably shifts position every day.
MarkH
  • Star Class
« Reply #3 on: Jan 04, 2015, 12:46:40 »
From my star charts there is a double star mag 5 ish exactly at that point, however, love joy might have overplayed it. It really depends when the image was exposed.
« Last Edit: Jan 04, 2015, 13:03:51 by MarkH »
MarkH
  • Star Class
« Reply #4 on: Jan 04, 2015, 13:02:35 »
Roger I think you have captured love joy but not where you originally thought. It may need confirmation by someone with a bit more expertees than me but I think in your image it is sitting just below eridanus 64.
Canadian Roger
  • Non-OAS
  • Nebula Class
« Reply #5 on: Jan 04, 2015, 14:18:49 »
Sorry. should have been a bit more specific...that picture is not mine, but Kenny's.  I went and had a look at his original, adjusting it slightly to darken the sky to see if the comet was visible.
MarkH
  • Star Class
« Reply #6 on: Jan 04, 2015, 14:44:35 »
Ooo my that's interesting, if that's the case then as MarkS says then its in about the right position. .......which means that Kenny may have captured some info on an unknown object. Can others check on that object just below eridanus 64.  :-?
« Reply #7 on: Jan 04, 2015, 14:56:14 »
Yes, Kenny caught the comet!!
Kenny's image was taken on the evening  of 27th Dec and shows a green blob in the precise position that my planetarium software says it should be (not where Roger indicated).
MarkH
  • Star Class
« Reply #8 on: Jan 04, 2015, 15:07:33 »
Mark can you check out that other object?
MarkH
  • Star Class
« Reply #9 on: Jan 04, 2015, 15:19:23 »
Sorry to speed up the search eridanus 64 is just below galaxy 1723.
Kenny
  • Cluster Class
« Reply #10 on: Jan 04, 2015, 15:20:44 »
Wow. Just checked Mobile Observatory. I agree. That's where Lovejoy was. I think the next object up/right could be M79.
 :cheesy:
MarkH
  • Star Class
« Reply #11 on: Jan 04, 2015, 15:25:25 »
Yes but check out the other object Kenny you may have made a new discovery.
Kenny
  • Cluster Class
« Reply #12 on: Jan 04, 2015, 16:06:20 »
Mark - Which object below Eri 64 are you referring to? Cross-checking with Stellarium and all appears to map to other stars.
MarkH
  • Star Class
« Reply #13 on: Jan 04, 2015, 16:18:44 »
About 1° left and 3° below eri 64 to the right of and about level with Lepus u.
Kenny
  • Cluster Class
« Reply #14 on: Jan 04, 2015, 16:47:38 »
If you mean the orange 'star', I think that is HIP 23203 though at Mag 8.05 it is brighter on this image than it should be.
