Photo Opportunity
Started by The Thing, Nov 01, 2012, 18:53:52
The Moon passes very close (~1.5deg) to Jupiter at around midnight tonight.
Hopefully the air will clear in time for some good shots, it's a bit murky here in Beckenham at the moment :(
JonH
It is pretty muddy looking here too, but the forecast says it is going to clear around 9 and will remain so until the early hours.
I hope so anyway!
Clear view from London Bridge station this evening, and just now while I was walking home from Orpington station too. Bit blustery, though.
Single shot by Canon 600d with Nikon 300mm lens on tripod.
1/400s at F/8  ISO400.
Cropped and scaled down by 1/3:
Here is the moon full size from that same image:
Here is Jupiter full size from that same image (but brightened by a factor of 4):
I was amazed that the dark bands are just visible.
BTW, this photo gives the opportunity to measure the relative surface brightness of Jupiter and the moon.  Jupiter is only 5 times dimmer than the moon but it would be 25x dimmer if it were made of the same material (since it is 5x further from the sun and there is a square law in operation).
I conclude that the moon surface is made out of out of some pretty unreflective stuff!
Ivor
I think you're right Mark, When I opened the fridge this morning I can confirm the cheddar in the fridge didn't reflect much light. As the weekend I shall buy a broader range of cheese so I can isolate the true composition.
Quote from: MarkS on Nov 02, 2012, 08:05:10
I believe the average albedo of the moon is only 9%, less than coal.
Quote from: The Thing
Pretty dark!
