Aluminium welding ?
Started by RobertM, Jun 03, 2010, 21:39:02
Is anyone able to do aluminium welding?  I need a strong bracket made up and was thinking of getting some 10-15mm aly and getting it welded in an L shape.  Last time I tried welding that stuff it ended up looking a bit like swiss cheese :(
Do you have a TIG, if so I'll do it.
Thanks for the offer Chris but I haven't and I may have found someone to do the work - fingers crossed.
I've used this stuff. It's the mutts...
http://www.techno-weld.co.uk/home.html
Much easier than mig/tig and you can use a standard blow torch. The only proviso is that the prep needs to be done properly.
Thanks Ian, it's an interesting method but hopefully I won't need to go that route.
Metal is ordered now.
