Sun Prominence animation
Started by Daniel, Apr 18, 2009, 23:36:52
Hi All, have to say, solar imaging is just the most relaxing astronomy you can do, I was out capturing this sitting on a deck chair, working everything remotely from the laptop under glorious sunshine.
Anyway, this is a 23 frame animation of 500 frames taken at 2 minute intervals, stacked in registax and stabilized in shake.
Check out the fireballs colliding!!!!
:O)
Pretty amazing animation Daniel.
Nice to see the action on the sun is hotting up  :roll:
Delphine
Fantastic Daniel, best I have ever seen!!!
That is exceptional Daniel, that Lunt certainly has very good definition.
Impressive Daniel - Don't suppose you done any calculations to detrmine how big those prominences are compared to say the diameter of the Earth...
Hi John, just whipped up a quick image for comparisson, the sun being 109 times wider across than the earth, which makes those "little" fireballs coliding with eachother probably the size of Asia!!!
:O)
Daniel,
That's a simply stunning animation!  Very well done.  It's good to see the earth's size in comparison.
