Author Topic: M106, NC4346, NGC4217 etc. etc.  (Read 474 times)
  • Mr October
  • Galaxy Class
    • AstroManche
« on: Mar 10, 2021, 09:44:04 »
240s x 75 = 4h, Gain 120 (Unity), Offset 4, Temp -5C
Image date, time and location:   2021-03-08, Manche, France
Telescope aperture and focal ratio:   TS1506UNC F4 TS GPU Coma Corrector
Camera and filters used:   ZWO ASI294MC Pro, Svbony 2" UV/IR
Processing applied:   DSS, StarTools
¯\_(ツ)_/¯ (Gallic shrug :))
    • Carole's images
Re: M106, NC4346, NGC4217 etc. etc.
« Reply #1 on: Mar 10, 2021, 12:11:51 »
That's come out very nicely Duncan.
I found this target unexpectedly difficult due to the faintness of the outer disc of the galaxy and difficult to extract colour from the galaxy.
Nice star colour.
  • Star Class
    • Astrobin
« Reply #2 on: Mar 10, 2021, 15:16:51 »
Duncan
There's a lot of detail in that image.  The colour of the stars is good and well saturated, yet the galaxies look green to me.  Can you colour balance the different channels for the galaxies to make the peaks coincide?  I am not familiar with the software you use but it may allow some other method of achieving this.
  • Mr October
  • Galaxy Class
    • AstroManche
« Reply #3 on: Mar 10, 2021, 15:23:49 »
That'll be all that alien plant life...
In StarTools Colour module there are two ways of reducing green, Cap Green which is a bit like SNCR but make green brown or yellow (yep). And reducing the green contribution to overall correction. I was a little conservative with the first and the automatic setting didn't do enough of the second🙁
  • Star Class
« Reply #4 on: Mar 10, 2021, 16:26:30 »
Looks really good Duncan.
The stars really make it.
Noel
  • Star Class
    • Astrobin
« Reply #5 on: Mar 10, 2021, 16:41:24 »
Duncan
If you can upload/send me the colour FITS master file I may be able to do something in PixInsight to it.
  • Galaxy Class
« Reply #6 on: Mar 11, 2021, 22:35:01 »
Very nice Duncan.  The brighter stars have very good colour but I would agree with Roberto that there is something going on with colour in the less bright objects.
  • Mr October
  • Galaxy Class
    • AstroManche
« Reply #7 on: Mar 13, 2021, 09:10:50 »
I've tweaked the colour after re-calibrating my monitor. I tried Photometric Colour Calibration in PixInsight and it didn't make much difference to M106 so I've manually tweaked in StarTools with 95% Cap Green setting. Hope this is more pleasing to the eye :), there is certainly more detail revealed e.g. star forming areas. Click on it for a big version as usual.
Click here for a Hyperleda annotated version showing all the galaxies and other objects detected by ASTAP
« Last Edit: Mar 13, 2021, 09:26:07 by The Thing »
  • Galaxy Class
« Reply #8 on: Mar 13, 2021, 10:49:20 »
There’s definitely more colour Duncan but the centre of M106 still has a green cast.
Did you colour calibrate it before stretching ?
    • Carole's images
« Reply #9 on: Mar 13, 2021, 11:11:31 »
I don't suppose you have an Ha filter?
The only images I have seen with much colour seems to be in Ha.  I had trouble with getting any colour from this target too.
  • Star Class
    • Astrobin
« Reply #10 on: Mar 15, 2021, 13:13:48 »
Photometric CC will still leave a greenish tint but it will certainly rebalance your star colours correctly.  I tried doing that on the image you posted but since it is already stretched and the background is essentially flat, there was little effect.  Colour balancing has to be done before the image is stretched.  If you send me your master raw, I can have a go at it.
« Reply #11 on: Mar 16, 2021, 15:55:59 »
That's a great result Duncan!  Beautiful galaxies.
PhotometricCC can give results that are sometimes not quite right with small (i.e. undersampled) stars.  It seems to works well with larger stars though.
