Question?
Started by Roy, Sep 24, 2020, 16:57:03
Roy
One for the imagers: if you operate a CCD camera binned e.g. 2x2 which means you loose 50% of linear resolution but effectively increase the sensitivity by a factor of about 4, but then you apply drizzle when processing, do you ultimately get an increase in sensitivity without any loss of resolution, i.e. something for nothing?  :D
Roy
Roy
No free lunch I'm afraid.  It really depends on the seeing and the sampling resolution you can achieve with your (binned) camera/telescope.
See the original paper here:  https://arxiv.org/pdf/astro-ph/9808087.pdf
You would benefit if at 2x2 you are still sampling well for your average seeing though.
I sometimes wondered the same thing, but then reasoned it could not possible work.
I reserve binning for the colour component only and use x1 for luminance and Ha where all the detail is.  The colour then needs to be resized to match the Lum/Ha.
Generally it speeds up my ability to capture in colour, to do colour x 1 would take me several sessions to build up a colour image and with UK weather even longer.
