Iridium flare
Started by Kenny, Apr 18, 2015, 22:57:05
Kenny
I captured the Iridium flare from Iridium 41 communications satellite at 21:48 this evening from Orpington. Canon 450D DSLR, 45 seconds at 33mm, f/6.3, ISO-1600. First time I've caught one, very pleased with the result. Stacked in DSS with 1 dark frame to remove rogue pixels.
MarkH
That's excellent Kenny, the longest I've witnessed  one for is less than a second.
Stacked with what Kenny? Surely the flare would only be on one frame?
Kenny
Yes. That's right. But adding a dark frame removes dodgy pixels.
Stacking involves more than one frame so I think you meant you calibrated the light frame in DSS ?
Quote from: RobertM on Apr 19, 2015, 22:35:48
Yeah that's what confused me.
Kenny
Thanks. I'm sure you are right. Still learning the lingo. :)
Kenny
Another one.
Iridium 18 'flare' caught at 21.33 this evening from Orpington in the dusk sky peaking at magnitude -8.1!! Other than a mild curve change in Adobe Photoshop CS2 to reduce the sky brightness and cropping the image, this is how it came out the camera. Unlike the last flare I captured, I haven't RGB balanced this one as it made the sky look too black /grey. Canon 450D at 33mm, f/6.3, ISO-1600. Longer 1 minute exposure to capture the full trail of the Iridium Communications Satellite.
Beautifully captured!  There's just no stopping you, is there!
RachelC
Wow. That is a great image!
Excellent capture Kenny.
