my first attempt
Started by MarkH, Dec 28, 2013, 14:34:24
MarkH
Image courtesy of Mr Shelly, thank you again Mark, this is my first attempt at processing. processed in paintshop pro x2, but I will be changing to photoshop. would be very grateful of criticism and opinions. :)
Very good for a first attempt at processing.  There are obviously tips and tricks, especially the reduce the core which you will learn as you go along.  Good to see that PSP worked as well as it did, but photoshop is definitely the way to go certainly at this stage.
