What printer/scanner would you recommend?
Started by Fay, Sep 09, 2012, 10:49:39
my Epson 950 printer has just given up the ghost. any suggestions you can give me for the above mentioned please? also is wireless ok
doug
#1
     Hi Fay.  I have an HP printer/scanner/copier and it`s very good.  Prints off quickly and very good copier.  The wireless connection with mine is first class.... I want to print something switch on the printer and ..... whoosh, there you go.  I think mine is an HP 110, if that`s any use.  Have a look on your browser for them.
    Doug.
Don't buy a Canon ! Whilst they have good print quality they also spend a lot of time cleaning the print heads and using ink making them very expensive to run.  I recently bought a Brother MFC-J825DW off Amazon but although it seems to sip ink and text quality is good I haven't done any colour prints yet.  My experience with the older Epson's has been good but not sure what the latest models are like.
Don't buy an Epson either. You want a make that has the ink head integrated into the cartridge so when you buy a new cartridge you get a new printhead. Epsons have a habit of clogging up unless you use them regularly as you use the same printhead all the time.
Thanks for your advice, but I have just come back with an Epson scanner/copier/printer. i was always pleased with print quality of photos on my Epson 915.
only just seen your replies
Bought a Epson PX730WD, it was like setting up a space shuttle launch!!
Hi Fay would be interested to see what you think of it cheers John.
Very nice so far, bit to learn, it gets good write ups.
Quote from: Fay on Sep 10, 2012, 15:03:14
Oh no Fay, whatever you do DON'T buy the Epson PX730WD. :-?
Too Late. :roll:
i am always quick off the starting blocks Tony............. :D
