1st attempt at moon map
Started by Rocket Pooch, Jun 30, 2004, 16:03:00
With the 80mmF5, VestaPro and iMerge
[ This Message was edited by: csuddell on 2004-06-30 08:05 ]
not looking bad. have you got a bigger version you can link to?
Hi Chris,
How many images did you have to stich together using imerge - Have you posted the full size image on your webpage - It looks very impressive - John
It was 4 images, I can create a bigger one if you like, this was saved with a 1:2 ratio.  It also only took 5 minutes to capture the frames and 8 mins to do the registax then 15 mins to put together with iMerge, 10 of which we're taken looking for the feather option, doh!
I think I should do a moon map with the LX90, this would really bring out some detail, but then again it would be about 50 images linked together.
Nice one Chris,
The hardest bit when taking it at full 2m focal length is not missing any of it.
