Last Night - The Epic
Started by mickw, Apr 21, 2011, 14:36:03
Mick,
There's no need for exposures longer than 5 min with a DSLR unless you are cooliong it and are using a very narrowband filter.
You may complain about it Mick but all the bits are starting to come together now.  Guiding is one big problem area overcome, calibration is something you'll have to make a habit.
QuoteMay DSC I'll give you an APT lesson. It's very simple! I think you think it's Nebulosity or Maxim
May I look in on this as well, I have not got around to doing anything with it yet as with my other problems it was just easier to use the software I already knew.
QuoteThere's no need for exposures longer than 5 min with a DSLR
I've assumed that you at least need to get a more than faint image on each sub to have something to work with once stacked
So I should just get loads of them ?  I presume more than an hours worth, perhaps 2 ?
I've just set up a 12 minute image in neb. it will be interesting how the guiding holds up.
That worked well, even got round(ish) stars, pity M101 was nowhere in sight  :(  Tracking seems to have gone to pot, then EQDir crashed along with PHD so had to reboot and realign everything.
Time to start again  :-?
Quote from: mickw
Exactly - loads of them.  A couple of hours worth at least.
Mark would that be "in general" or specifically on the Tak
My Burgess at f6.6 would be about 4 stops slower than the Tak
Mick,
It still applies at F6.6
No need to go beyond 5min.
