Synscan HELP!!
Started by Fay, Apr 09, 2011, 21:01:55
Synscan is saying "no link to MC" stand alone mode.
Has anyone a clue what it means please?
Its broken  :twisted:
Have you plugged guide plug into handset socket, or something similar ?
No the handset says initialising and i can put date etc in but it was ok last time i used it. I wonder if I can try the eq5 handset?
Tested the handset on Mark's mount. Tried different combinations of cable & handset. As EQMOD moved my mount, it is now assumed the handset is at fault. I did a firmware update, which worked ok, but handset is still the same.
Thanks to Bern, Modern Astronomy, who I bought it off, he is getting a replacement handset from OV. This is when it pays to order from reliable sources.
