M51 QSI 070311
Started by Fay, Mar 08, 2011, 14:18:17
Well I had to do something last night. Would have normally done a galaxy with the 120.
There is some star flare, but have ordered the correct spacer. Could be some gradient, but difficult to see on this computer.
QSI/ED80 20x300, L, 0.8fr, flats dks bias, stacked in DSS
Quite a learning curve. It is different to the Atik. Have to remember a lot of new things & still learning. Once I have focus & framing, I should be better.
Well done Fay, nice start
Well thanks Mick. I would normally have used a CLS filter, but nowhere to put it if I am using a fr
Nice capture for a start,
Nice start Fay, not too shoddy for a first light :)
well Robert, thankyou, I will be ok once I know why what etc etc. It was only a trial I had messed about for 3 hours!!!!
PhilB
Very nice, Fay. Especially so given the experimental nature of the session.
That's a great first light Fay.
I quite like seeing a lonely galaxy sitting in a wide star field like that - it gives a real sense of perspective.
I'm quite surprised how much faint stuff can be seen - especially as you did this without a filter.
Well I think I have it sussed now. (famous last words, I will probably eat them before the night is over) Framed @ 4x4 took 7secs, focused, bit dubious, but ok, 2x2, no figures showing in X & Y & I think if the shape of the rectangle is not to aa's liking , it does not show the star in the focus box. That is what it looks like anyway.
A minor glitch, it was only doing the first sub of a sequence & not saving it,  not sure why. I closed aa down & restarted & it is saving now.
That has happened a few times, I will suddenly realise what is not liked.
I am absolutely worn out today & was just going outside to sort a couple of things, but happy to be out longer now it is working ok.
Thanks Mark, yes I will only be able to use a cls with galaxies, if I do not use the flattener & put the 2" nosepiece on the QSI & put my 2" filter in the end. Perhaps I don't need a flattener for a galaxy if it is cropped.
Do you mean you don't have a filterwheel?
Yes but the L filter is used for galaxies. I used to screw a cls on the end of the nose
Lovely image Fay. You must try this in colour.
Why don't you put the CLS in the filter wheel?
