AudelaA
Started by Rocket Pooch, Nov 20, 2010, 10:03:59
This is a free open source camera control and processing system,;
AudeLA 2.0 open source software is now available. This is *free*
software for astronomy used by lot of amateur astronomers but also
professional astronomers (robotic TAROT telescope is controled by AudeLA
for exemple; 1.93m OHP telescope is also controled by AudeLA for GoTo
and autoguiding; ...).
MS-windows version now supports QSI camera among others. It does support
windowed/cropped acquisition and binning of course. For Linux, it does
require some additional work to integrate linux driver into AudeLA. As
any Open Source sofdtware, anyone is welcome to help and provide some
coding resources! :-)
_/*Main Features:*/_
Aiming and controlling equipment
Align assistant with the polar scope (Takahashi or EQ6)
Align assistant with the King method
Focusing assistant
Pipeline for the aiming model
GOTO function using integrated catalogs (planets, asteroids,
Messier objects, reference stars, NGC, IC, Moon)
GOTO function using another charting planetarium tool (Guide,
Carte du ciel , Skychart)
Remote control from a computer
Check position and time via GPS (through a serial or Ethernaude link)
Control of filter wheels
Virtual control pad
Autoguiding
Supported telescopes : LX200 protocol (with special features of
Audecom, Skysensor, losmandy, It-lente, Mbartels), Ouranos, Temma,
Ascom, Celestron
Link: serial port, USB/Serial adapter
Capturing Images
Capture modes: serial, continuous, windowed, binning, scan, video.
Capturing videos with a Webcam (Windows only).
Characteristics of the optics (CCD field, binning, focal lengths,
etc.).
Capturing scans (drift-scan and normal scan)
Display of a reticle for centering purposes
Pipeline for supernovae survey
Pipeline for asteroid photometry
Supported cameras: Audine, Hi-Sis, SBIG, CB245, Starlight, Kitty,
Webcam, TH78521, SRC1300XTC, Canon EOS, Coolpix, Andor
Supported links: parallel port, USB port, Ethernaude, Quickremote
(USB/parallel converter)
Long exposure option for webcams and DSLRs (via serial port,
USB/serial adapter, parallel port or QuickRemote interface)
Displaying Images
Zoom, mirror, windowing, full screen
Transfer functions (linear, log, exponential, arc-tangent).
Automatic adjustment of viewing thresholds.
Changing colour palettes
Multi-window display
Viewer with animation or blinking
Processing Images
Processing one image (add , subtract, divide, etc.)
Processing series of images (register, add, subtract, etc.)
Geometric operations (mirrors, windowing, resampling)
Optimizing dark frame, subtracting sky background
Filters (high pass, low pass, gaussian, median)
Wavelets, logarithms
Statistics on the image, Fwhm, Flow, Photocentre
Histogram, section
Image selection
Processing colour images (RAW?CFA, CFA?RGB, R+G+B?RGB, etc.)
Advanced Processing of Images
Automatic pre-processing (make a dark frame, a flat field,
registering)
Astrometric calibration
SpcAudace <http://bmauclaire.free.fr/spcaudace/> (automatic
spectrum processing, spectral astrophysics analysis)
Does it make the tea?  :cheesy:
Looks like its got all the bases covered.
If its as good as it says it is, it might just be the only piece of software you need for imaging.
(not processing just acquisition)
