Scary things with a 450D
Started by mickw, Oct 19, 2009, 15:09:29
wow, thats a fantastic mod.
Wow! Indeed it is. Quite impressive. A good way to get a cheap cooled one-shot colour cam too.
If you ask him nicely, I'm sure Mark would like to practice on a D3 before damaging a perfectly good 350D.
And Tony, well Tony would just like to practice on anything breakable ;)
Quotemight try
There is no try - do or don't do !
You have already mastered the light sabre  ;)
May the farce be with you.............................
Mick,
That's a brilliant find - well done!  It gives me lots of ideas for my 350D Peltier mod.
I like the way he disconnects ribbon cables to determine if they are important or not!
However, it seems a bit odd that he appears to have put the heatsink inside the aluminium box where it will warm everything up.  Or have I misunderstood this part (first image in section 4).
His particular Peltier chip consumes 3.7A at 12v - I would need a whole car battery just dedicated to cooling.
Quoteheatsink inside  the aluminium box
I hadn't noticed that, there doesn't even appear to be an airflow over the heat sink, just a fan trying to suck air out of a sealed container.
Although he has sealed the "camera" in a poly bag which might help a bit.
He has managed some impressive improvements for what looks like an inefficient design though.
Also regarding your coldfinger clearance issues between the CCD - are you aware that you can get copper shim in various thicknesses down to around .003"
Quote from: mickw
That sounds interesting.  Where from?
