Author Topic: EQ6 2 meter fl guided 4 minute subs 314l  (Read 646 times)
  • Non-OAS
  • Galaxy Class
« on: Oct 12, 2008, 23:33:29 »
it worked
stack 5x4 minute at the full 2 meters.just a star field
  • Galaxy Class
Re: EQ6 2 meter fl guided 4 minute subs 314l
« Reply #1 on: Oct 13, 2008, 08:46:42 »
Looks like RA drift between subs - were you using PHD by any chance ?
  • Non-OAS
  • Galaxy Class
« Reply #2 on: Oct 13, 2008, 12:59:47 »
Na AA, its probably a little flexture in the filter wheel, I had to goto the manual one again, the stars are not very elongated so its not a big issue, nothen that a good set of rings wont cure along with the ATIK Motorised filter wheel v3 whenever I get it.
  • Observing Consultant
    • Electronicle
« Reply #3 on: Oct 13, 2008, 13:03:58 »
Very impressive Chris. Will be interesting to see what you can do with this set up. Any idea what the weight is? Have you overloaded the EQ6 ? What have you done to dampen oscillations?
  • Non-OAS
  • Galaxy Class
« Reply #4 on: Oct 13, 2008, 14:08:33 »
Err I think its 10kg all in, I have done nothing to calm things down, appart from the fact the 55kg pier is bolted to 1.5meter square on concrete, not a portable setup I must admit, but it seems to work.
But there is a balancing trick you need to know, John and Fay knows what it is :-)
