Bubble and M52
Started by RobertM, Aug 23, 2008, 09:46:24
It wasn't very good last night after starting off very promising so this didn't get as many subs as it needed.  One day I'll manage to get an imaging sequence unbroken by clouds or mishaps.  Ended up pushing the processing more than I wanted to bring out the fainter nebulosity.
8 x 300s Sky 90 at f/4.5 and SXV-H9 binned 1x1 and Astronomik 13nm Ha filter
Also caught a Perseid on one of a set of 60 second subs:
well that's much better, lovely round stars (collimation worked) and it actually look 3d, very good, id be happy with that, but annoyed at that cloud that came in  :cry:
yep Robert that is pretty darn excellent - shame about cloud though kinda gives it a 'milky appearance'.
Great result though... John
Thanks.  Collimation is still a tad out so will get it more precise for next time, likewise for Polar alignment so 6/10...
John,  I excluded the cloudy subs and on with the 747 so that 'milky appearance is just nebulosity (I think !).
Robert,
Great images, especially the second with the Perseid, lovely wide field.
Excellant Robert, it is a great image!!!!!!!! Only 8x300 secs!!!!!!
Nice image Robert. Plus a Perseid too !
That streak looks a lot more like (say) an Irridium flare than a meteor. It tails off both before and after the bright point, and the apparent brightness profile is near enough symmetric.
Anyone else got any Irridium flare photos with which we could compare it, or is this a first?
I've also seen meteor pics like that. They skip off the atmosphere or something breaks off and flares up.
QuoteI've also seen meteor pics like that. They skip off the atmosphere or something breaks off and flares up
the famous one.
http://www.maniacworld.com/tetons-meteor-a-near-miss.html
Just found the youtube one as well.
http://www.youtube.com/watch?v=7M8LQ7_hWtE
Must admit it does look very similar to Iridium flare pics on the web so it could be.  If it helps track it down the exposure was 60 seconds and the timestamp on the image was:
'2008-08-22T22:26:47' /YYYY-MM-DDThh:mm:ss observation start, UT
Can't find any likely candidates with Starry Night. The predictions I ran show very few possible candidates for that time, and I've no idea whether any tracks went anywhere near the area. These are all the ones anywhere near that time:
Ground Station    : High Elms, Farnborough, Kent, England   ---   JO01AI
Time Zone         : UTC (+0.00 h)
                           in eclipse *  in daylight o
Date       Rising at    Peak elevation      Setting    Height Satellite
Y M D  Time      Az.  Time      Az. El  Time      Az. (peak) Name
080822  22:06:58  355  22:14:28   34 88  22:22:14* 178        IRIDIUM 70 [+]
080822  22:09:59  313  22:19:09   39 64  22:31:02* 123        NOSS 8 H
080822  22:10:43* 210  22:17:57  284 33  22:25:19  359        IRIDIUM 77 [+]
080822  22:13:14* 166  22:20:46  257 79  22:28:25  345        BO-47 & BO-48
080822  22:15:47  299  22:22:48   10 26  22:31:57   77        NOSS 5 A
080822  22:16:14  354  22:23:43  261 77  22:31:21* 182        IRIDIUM 62 [+]
080822  22:16:53* 191  22:22:18  264 29  22:27:50  339        IGS 1A
080822  22:17:23    2  22:26:44   85 51  22:43:55* 164        ISIS 1
080822  22:20:07* 215  22:27:13  287 28  22:34:27  358        IRIDIUM 15 [+]
080822  22:21:24  244  22:27:24  320 40  22:33:55   41        GENESIS 2
080822  22:25:19  353  22:32:49  270 65  22:40:26* 187        IRIDIUM 63 [+]
080822  22:26:49* 189  22:33:23  262 35  22:40:14  339        ALOS DAICHI
080822  22:31:58* 215  22:39:12  288 31  22:46:34    1        USA 32
080822  22:33:11  300  22:40:03   12 25  22:48:56   78        NOSS 5 C
080822  22:34:33  352  22:41:55  273 55  22:49:33* 192        IRIDIUM 64 [+]
I've seen a meteor like that you tube one over abbey wood years ago, it was glowing bright green and was in broad daylight!
Just finished processing the extra 24 x 1 min subs making a total of 64 mins.  It has more detail an I think it's slightly better ?
Quote from: Daniel on Aug 26, 2008, 20:47:53
When I was about 9 years old I saw bright green ones in broad daylight too over the river mersey.
