"Plutoid" Dwarf Planets beyond Neptune...
Started by Rick, Jul 22, 2008, 14:06:37
Third plutoid christened 'Makemake'
The International Astronomical Union (IAU) has declared that the trans-Neptunian dwarf planet formerly dubbed 2005 FY9, or "Easterbunny", will henceforth be known as the equally silly "Makemake".
More: http://www.theregister.co.uk/2008/07/21/makemake_plutoid/
it's all in the pronunciation I thing.
is it,
make-make
mackie-mackie
mackem-akey
mac-emackey
or even with silent Ms, a-cake?
Why didn't they just leave it as Easterbunny? We should have more silly names for solar system objects. I'd love them to name an asteroid Potato.
p.s. Did you know that in the asteroid scene in Star Wars that one of the asteroids was actually a potato?
it's shame they couldn't be collectively known as potatoids.
I'm guessing it's something like Ma-Key-Ma-Key (or maybe Kay rather than Key)...
Quote from: Mike on Jul 22, 2008, 14:38:44
So that's where that worm came from... ;)
Astronomers announced today that a new "minor planet" with an unusual orbit has been found just two billion miles from Earth, closer than Neptune. Using the Sloan Digital Sky Survey, astronomers detected a small, comet-like object called 2006 SQ372, which is likely made of rock and ice. However, its orbit never brings it close enough to the sun for it to develop a tail. Its unusual orbit is an ellipse that is four times longer than it is wide, said University of Washington astronomer Andrew Becker, who led the discovery team. The only known object with a comparable orbit is Sedna — the distant, Pluto-like dwarf planet discovered in 2003. But 2006 SQ372's orbit takes it more than one-and-a-half times further from the Sun, and its orbital period is nearly twice as long.
http://www.universetoday.com/2008/08/18/astronomers-find-a-new-minor-planet-near-neptune/
The International Astronomical Union (IAU) has decreed that the object formerly known as 2003 EL61 will henceforth be addressed as "Haumea", and joins Ceres, Eris, Makemake and Pluto in the solar system's league of dwarf planets.
The IAU describes trans-Neptunian Haumea as a fast-spinning "bizarre object with a shape resembling a plump cigar", with a diameter "approximately the same as that of the dwarf planet Pluto".
More: http://www.theregister.co.uk/2008/09/18/haumea/
The dwarf planets and other objects that litter the Kuiper belt in the far reaches of our solar system are a strange bunch, but astronomers have found what they think might be the weirdest one.
Discovered on Dec. 28, 2004 (catalogued as 2003 EL61 and nicknamed "Santa" for a time), the minor planet now known as the dwarf planet Haumea, to honor its Hawaiian discovery, is as big across as Pluto and one-third of its mass, but shaped something "like a big squashed cigar," said one of the astronomers who studies the object, Mike Brown of Caltech.
From its shape to its satellites, Haumea is a strange object, but one that could shed light on the history of collisions in the solar system, as well as the early environment of the Kuiper belt, which sits out beyond the orbit of Neptune.
More:   http://www.space.com/scienceastronomy/090622-mm-kuiper-haumea.html
Strange Dwarf Planet Has Red Spot
A dwarf planet in our solar system, called Haumea, is known for its unusual shape and fast spin. Now astronomers have discovered another distinguishing feature: a dark red spot which appears to be richer in minerals and organic compounds than the surrounding icy surface.
Haumea, discovered in 2004, orbits the Sun beyond Neptune, in a region known as the Kuiper Belt. It is classified as a dwarf planet — a celestial body that is big enough to have been rounded by its own gravity, but has not cleared its neighboring region of similar objects. There are four other dwarf planets: Ceres, Pluto, Eris and Makemake. Haumea is the fourth largest dwarf planet.
More:   http://www.space.com/scienceastronomy/090915-Haumea-dark-spot.html
Hubble Discovers Moon Orbiting the Dwarf Planet Makemake
Peering to the outskirts of our solar system, NASA's Hubble Space Telescope has spotted a small, dark moon orbiting Makemake, the second brightest icy dwarf planet - after Pluto - in the Kuiper Belt.
The moon - provisionally designated S/2015 (136472) 1 and nicknamed MK 2 - is more than 1,300 times fainter than Makemake. MK 2 was seen approximately 13,000 miles from the dwarf planet, and its diameter is estimated to be 100 miles across. Makemake is 870 miles wide. The dwarf planet, discovered in 2005, is named for a creation deity of the Rapa Nui people of Easter Island.
The Kuiper Belt is a vast reservoir of leftover frozen material from the construction of our solar system 4.5 billion years ago and home to several dwarf planets. Some of these worlds have known satellites, but this is the first discovery of a companion object to Makemake. Makemake is one of five dwarf planets recognized by the International Astronomical Union.
More from NASA
This Hubble Space Telescope image reveals the first moon ever discovered around the dwarf planet Makemake.
The tiny moon, located just above Makemake in this image, is barely visible because it is almost lost in the glare of the very bright dwarf planet. The moon, nicknamed MK 2, is roughly 100 miles wide and orbits about 13,000 miles from Makemake. Makemake is 1,300 times brighter than its moon and is also much larger, at 870 miles across.
The Makemake system is more than 50 times farther than the Earth is from the sun. The pair resides on the outskirts of our solar system in the Kuiper Belt, a vast region of frozen debris from the construction of our solar system 4.5 billion years ago.
Previous searches for a moon around Makemake turned up empty. The moon may be in an edge-on orbit, so part of the time it gets lost in the bright glare of Makemake.
MORE....
2007 OR10: Largest Unnamed World in the Solar System
Dwarf planets tend to be a mysterious bunch. With the exception of Ceres, which resides in the main asteroid belt between Mars and Jupiter, all members of this class of minor planets in our solar system lurk in the depths beyond Neptune. They are far from Earth - small and cold - which makes them difficult to observe, even with large telescopes. So it's little wonder astronomers only discovered most of them in the past decade or so.
Pluto is a prime example of this elusiveness. Before NASA's New Horizons spacecraft visited it in 2015, the largest of the dwarf planets had appeared as little more than a fuzzy blob, even to the keen-eyed Hubble Space Telescope. Given the inherent challenges in trying to observe these far-flung worlds, astronomers often need to combine data from a variety of sources in order to tease out basic details about their properties.
Recently, a group of astronomers did just that by combining data from two space observatories to reveal something surprising: a dwarf planet named 2007 OR10 is significantly larger than previously thought.
More: http://www.jpl.nasa.gov/news/news.php?feature=6509
