Light Box
Started by Fay, Apr 20, 2008, 20:54:43
Great Mike, because you described it as foam board, I assumed it would be like cardboard or something.
Being that I have developed a fetish for looking at any box anyone is carrying & weighing it up, & only looking at box's when in M & S, I will go to Hobbycraft tomorrow.
Thanks a lot.
Weighing it up?  I thought "light box" meant it wasn't dark!
Quote from: Fay on Apr 22, 2008, 12:27:46Being that I have developed a fetish for looking at any box...
You'll spend ages in Hobbycraft then !   :o
Don't know whether it helps but I found this artical on buiding a light box today...
http://www.asignobservatory.com/LightBox.aspx
I was looking for that site Robert, good.
My lightbox has been started now. I noticed in 2005 Mike had put details of how he made his box on UKAI.
Blimey if Mike had to put instructions on UKAI about how to make a box it reinforces my opinion of most people on that site....
The light box bulb wires are now going to be connected to the cigarette connector that goes into the battery.
Can anyone tell me which position in the connector the red goes please?
Should be the one going to the centre pin of the plug.
Bonus Info:
This months Practical Astronomer has articles on Flats and Light Boxes  ;)
Thanks Mick, for wire information. Yes I saw the articles, would you believe they are in there this month!
Put the scope thru the hole in the light box & it seems like a snug fit, but it does not stay in that position, it settles at an angle, with the box weight. Does the scope glass have to be level with the bit of plastic with the lights behind?
Also, when you take a light frame & hold the mouse on the image, I will aim for around 28,000 ADU, should the mouse show this level over the whole frame or will it vary?
Does it have TWO layers of foambaord so that it holds it in place?
NO, I think that is the problem. Will have to be sorted! Thanks Mike
Should have followed my design ;)
