Getting rid of jet lines with Maxim
Started by Fay, Feb 10, 2008, 08:39:17
Mike,
please can you tell me how you get rid of the jet trails on images, in Maxim.
Thanks,
don't you just omit the suspect subs from the stack....or am I misunderstanding what you are trying to do?
Well I wanted to use all of them. There is a function in Maxim that will auto delete anything that is not common to the other subs.
Use the Sigma stack - that should do the trick.
