Editing colour in channels PS CS
Started by Fay, Jan 18, 2008, 10:04:46
Please does anyone know how to show the R G B images, in Channels, in colour for editing. I can only get a grayscale image unless looking at the layered RGB image.
Thanks,
If I understand the question correctly you will need to click on the Channels TAB?
Not sure if that the correct answer to the question though?
I have the individual R G B layers in Channels, but they look grayscale. Whereas if you look at the combined RGB, it is in colour.
How can you know edit the individual R G B channels if it is grayscale? Is there a way of converting each channel into colour for editing?
eg. my stars are bright yellow in the combined RGB image. I need to tone it down.
Hope that is clearer
if you goto Edit Preferences Displays and cursors, theres a little tick box to show channels in colour, :lol:
Fay - I think Mac had set your laptop up like this before so you could see the colour channels in the respective colours & you didn't like it so I don't quite understand what you are trying to do. Normal way (or the way I do it & Don Waid) is to have your four channels L,R,G,B all in greyscae & then create a  LRGB coloured image. If you leave it layered & edit the individual greyscale channels then you can see immediate effects on the composite LRGB image.
Thanks Mac, that is just what I wanted know. I wondered if that was the way to do it.
The channels are supposed to be greyscale.
