Light polution classes.
Started by Mac, Jan 14, 2008, 13:28:41
Just found this whilst surfing.
Class 1: Excellent dark-sky site. The zodiacal light, gegenschein, and zodiacal band are all visible - the zodiacal light to a striking degree, and the zodiacal band spanning the entire sky. Even with direct vision, the galaxy M33 is an obvious naked-eye object. The Scorpius and Sagittarius region of the Milky Way casts obvious diffuse shadows on the ground. To the unaided eye the limiting magnitude is 7.6 to 8.0 (with effort); the presence of Jupiter or Venus in the sky seems to degrade dark adaptation. Airglow (a very faint, naturally occurring glow most evident within about 15 degrees of the horizon) is readily apparent. With a 32-centimeter (12½) scope, stars to magnitude 17.5 can be detected with effort, while a 50-cm (20-inch) instrument used with moderate magnification will reach 19th magnitude. If you are observing on a grass-covered field bordered by trees, your telescope, companions, and vehicle are almost totally invisible. This is an observer's Nirvana!
Class 2: Typical truly dark site. Airglow may be weakly apparent along the horizon. M33 is rather easily seen with direct vision. The summer Milky Way is highly structured to the unaided eye, and its brightest parts look like veined marble when viewed with ordinary binoculars. The zodiacal light is still bright enough to cast weak shadows just before dawn and after dusk, and its color can be seen as distinctly yellowish when compared with the blue-white of the Milky Way. Any clouds in the sky are visible only as dark holes or voids in the starry background. You can see your telescope and surroundings only vaguely, except where they project against the sky. Many of the Messier globular clusters are distinct naked-eye objects. The limiting naked-eye magnitude is as faint as 7.1 to 7.5, while a 32-cm telescope reaches to magnitude 16 or 17.
Class 3: Rural sky. Some indication of light pollution is evident along the horizon. Clouds may appear faintly illuminated in the brightest parts of the sky near the horizon but are dark overhead. The Milky Way still appears complex, and globular clusters such as M4, M5, M15, and M22 are all distinct naked-eye objects. M33 is easy to see with averted vision. The zodiacal light is striking in spring and autumn (when it extends 60 degrees above the horizon after dusk and before dawn) and its color is at least weakly indicated. Your telescope is vaguely apparent at a distance of 20 or 30 feet. The naked-eye limiting magnitude is 6.6 to 7.0, and a 32-cm reflector will reach to 16th magnitude.
Class 4: Rural/suburban transition. Fairly obvious light-pollution domes are apparent over population centers in several directions. The zodiacal light is clearly evident but doesn't even extend halfway to the zenith at the beginning or end of twilight. The Milky Way well above the horizon is still impressive but lacks all but the most obvious structure. M33 is a difficult averted-vision object and is detectable only when at an altitude higher than 50 degrees. Clouds in the direction of light-pollution sources are illuminated but only slightly so, and are still dark overhead. You can make out your telescope rather clearly at a distance. The maximum naked-eye limiting magnitude is 6.1 to 6.5, and a 32-cm reflector used with moderate magnification will reveal stars of magnitude 15.5.
Class 5: Suburban sky. Only hints of the zodiacal light are seen on the best spring and autumn nights. The Milky Way is very weak or invisible near the horizon and looks rather washed out overhead. Light sources are evident in most if not all directions. Over most or all of the sky, clouds are quite noticeably brighter than the sky itself. The naked-eye limit is around 5.6 to 6.0, and a 32-cm reflector will reach about magnitude 14.5 to 15.
Class 6: Bright suburban sky. No trace of the zodiacal light can be seen, even on the best nights. Any indications of the Milky Way are apparent only toward the zenith. The sky within 35 degrees of the horizon glows grayish white. Clouds anywhere in the sky appear fairly bright. You have no trouble seeing eyepieces and telescope accessories on an observing table. M33 is impossible to see without binoculars, and M31 is only modestly apparent to the unaided eye. The naked-eye limit is about 5.5, and a 32-cm telescope used at moderate powers will show stars at magnitude 14.0 to 14.5.
Class 7: Suburban/urban transition. The entire sky background has a vague, grayish white hue. Strong light sources are evident in all directions. The Milky Way is totally invisible or nearly so. M44 or M31 may be glimpsed with the unaided eye but are very indistinct. Clouds are brilliantly lit. Even in moderate-size telescopes, the brightest Messier objects are pale ghosts of their true selves. The naked-eye limiting magnitude is 5.0 if you really try, and a 32-cm reflector will barely reach 14th magnitude.
Class 8: City sky. The sky glows whitish gray or orangish, and you can read newspaper headlines without difficulty. M31 and M44 may be barely glimpsed by an experienced observer on good nights, and only the bright Messier objects are detectable with a modest-size telescope. Some of the stars making up the familiar constellation patterns are difficult to see or are absent entirely. The naked eye can pick out stars down to magnitude 4.5 at best, if you know just where to look, and the stellar limit for a 32-cm reflector is little better than magnitude 13.
Class 9: Inner-city sky. The entire sky is brightly lit, even at the zenith. Many stars making up familiar constellation figures are invisible, and dim constellations such as Cancer and Pisces are not seen at all. Aside from perhaps the Pleiades, no Messier objects are visible to the unaided eye. The only celestial objects that really provide pleasing telescopic views are the Moon, the planets, and a few of the brightest star clusters (if you can find them). The naked-eye limiting magnitude is 4.0 or less
Well looks like Abbey wood is well in to the Class 9
:cry:
Reading that i'd say Class 5 from my garden.
I'd probably say 8 for me or on exceptional nights borders on 7.....
Mike - you have pretty damn good skies if you are a 5..... Mag 6 with naked eye.....
I also like to test NELM (Naked Eye Limiting Mag) by counting stars in great square of Pegasus as follows:
0 stars mag 4 or worse
1 stars mag 4.5
4 stars mag 5
7 stars mag 5.5
13 stars mag 6
30 stars mag 6.5
Normally about 1 at best....
I'd like to learn more about this light pollution you speak about. Where are the classes held? Can it get a grant for making light pollution if it's part of my studies?
I reckon mine is about 7, possibly pushing 6, and that's given some parts of my garden are not overlooked by streetlighting at all.
I'd put Tuesnoad between 3 and 4. I don't think anyone's walked into a telescope they didn't see yet, even on the best nights.
i'll give pegasus a go.
I had to do something similar a couple of years ago for my degree.
When i last worked out my limiting magnitude, it was 4.33.
hopefully it hasn't got any worse.
I'll do a limiting magnitude test next clear night I get. I reckon I can get down to 5.6 if the sky is moisture free.
I would say I am class 7 Mac
I don't think I've seen anything fainter than 4.5 from Sidcup which makes me a class 8.   But Ian (lives not far away) reckons class 7 pushing 6 i.e. magnitude 5.0 or better.
Next time we get a clear moisture free night I'll take a look.
I must be a class 12  :(, and if you look closely and stand at the right end of the Mottingham you can make the outline of Ursa Major using the streetlights and floodlight on the football pitch changing rooms instead of stars. (you have to go to Catford Bus station to see Orion.) ;)
Seriously now Class 8, but do have the occasional Class 7.
I'm definitely class 8.
