M33
Started by Whitters, Oct 07, 2007, 20:10:19
Six 10 minute subs, WO 110 f6.5, Starlight X-Press MX916. Astronomik IR block.
Processing Curves and unsharp Mask
Nice Paul,
Faint spiral structure is really starting to show through... looks like you may have pushed a little too hard in processing as white's looked clipped... Great shot though & good to see you imaging again...
Oscar the Cat
Hi John,
I was trying to show the centre of the galaxy, so I have brought the white level down, clipping some of hte stars. I need to learn how to enhance the faint outer without burning out hte centre. Any suggestions?
Paul
Nice one Paul. I would agree with John though that you have gone OTT with the unsharp mask. You have the original FITS files so you can always redo. If you are subtle with the unsharp mask or don't do it at all then it should be better.
I find that producing a curve shaped like a steep sided hill with a flat top produces the desired result re: bringoput out detail but not burning the core. However, I am sure John will giev you better advise about that as hsi recent processing of M33 was spot on.
Hi Paul,
stack it normally, then do sigmoid scalling in AIP, its in the brightness scaling, the stars will stay but you can bring out the backgroud, thats how I did my M13.
Oscar the Cat
Thanks folks, I'll have a go
