Some wide field Constellation shots
Started by Whitters, Aug 03, 2007, 00:14:47
First shot would have been better if I hadn't kicked the tripod when going for the cable release. and the second wasn't helped by that darn plane coming straight out of Gatwick.
Left hand image details;
Shooting Date/Time 02/08/2007 21:36:35 UT
Tv(Shutter Speed)  357Sec.
Right hand image details;
Shooting Date/Time 02/08/2007 21:50:55 UT
Tv(Shutter Speed)  327Sec.
Applies to both
Av(Aperture Value)  F4.5
ISO Speed             100
Lens                     EF-S18-55mm f/3.5-5.6
Focal Length          18.0 mm
Paul,
Can you identify constellation - Is this around summer triangle... what's the bright star mid top... There is a lot more in these images - I did a stretch on top one & dust bands in milky way etc. are clearly visible - you should adjust levels/ curves on raw... Also when I stretched you can see that there are a few satellite trails right through the image.... :-(
Good shots - John
Hi John,
Big bright star is Vega with the rest of lyra below and to the right. Cygnus is below running bottom left to upper right. The trails on the image without the big bright airplane, are other aircraft trails. I was running the camera with auto darks. Found out last night that there is a big hot spot  :-? if I dont take darks so I'm sending it back to Canon .
