11-Day Moon
Started by JohnP, May 09, 2006, 09:28:45
Hadn't intended imaging last night but popped my head outside around 9'ish & it looked quite clear so I decided I'd give my new WO ZS66 SD-APO it's 'first light'. I quickly threw it on the LXD75 & did a quick alignment & then slewed to the moon. I was impressed with the view & managed to capture a single exposure through the EOS-300D before clouds rolled in.... :-(
Anyway here it is - Image is just a crop of the moon full size... I reckon that I could fit approx 7 X 5 moon diameters into full frame - i.e. FOV 3 1/2 deg by 2 1/2 deg so I'm looking forward to trying some widefield stuff down at DSC..
Cheers,  John
Nice and crisp, did you sharpen it at all, or was that what it came out like?
Also how small was the moon in a full frame?
Hi Chris,
Yes I sharpened a little (not much though) & adjusted curves... that was it. I captured image in raw format which is always a little soft...
Below you can see full frame - which as you know is 3072 X 2048 - Like I said above I reckon you could fit 7 X 5 moons in full frame - approx 3 1/2 deg X 2 1/2 deg...
Cheers,  John.
John, looks promising! I wouldn't mind a quick test shot with my SXV-H9 on that scope at DSC if I can please. I am considering getting one myself for those huge nebulaes out there and I am interested to know the FOV I would get.
No Problems - I'd be interested to see results as well.... Cheers, John
Lovely image John,
not that it needs enhancing but you could also do an AVI through your camera and process it through Registax, just a thought from a novice.
I'd be happy with that image whatever way
Cheers Tony, The EOS-300D doesn't have Video capture so No I couldn't - I could take multiple single frame images though & stack them in Registax if I wanted. The beauty of using the 300D is that I can take the whole moon in one shot (nice wide FOV).
Thks again,  John
Nice image John
