Ring system discovered around dwarf planet Quaoar leaves astronomers puzzled
Started by Rick, Feb 09, 2023, 12:22:56
A ring system has been spotted around dwarf planet Quaoar at a distance astronomers didn't believe was possible, defying astronomical theories on how these structures form.
Quaoar lies in the Kuiper belt beyond Neptune. The icy rock is 1,121 kilometers (697 miles) wide, about half the diameter of Pluto. Quaoar is a distant object with interesting properties, including signs it may harbor ice-spewing volcanoes and a ring system.
Debris compressed into rings orbiting planets are found around the gas giants Saturn, Jupiter, Uranus and Neptune, and dwarf planets Chariklo and Haumea. All the ring systems lie relatively close to their host planets within a distance known as the Roche limit.
The Roche limit states that ring systems can only form within a distance where the tidal forces from a larger body are more powerful than a smaller object's own gravitational forces.
More: https://www.theregister.com/2023/02/09/dwarf_planet_ring_system/
