Cant change AF mode on Canon 600D.
Started by Fay, Apr 20, 2020, 12:13:17
I am probably doing something daft. I only use 600D for landscapes or I did set it up with BYE last week.
I cant change the AF mode and so cant get it to autofocus. have cleaned contacts and changed lenses, but cant figure it out. it is a  coincidence that I set it up to work with BYE and attempted to set up with APT, which will not work (have sent message to IVO but as yet no answer)
has anyone any clues. thanks
well Thomas Cameras was open in Southborough, after a few tests he said to clear all settings etc , which i did and it is now working
Glad you cleared that up Fay I was in panic mode thinking you had gone out during the lock down.
