Solar Scope Advice
Started by ApophisAstros, Feb 07, 2020, 18:46:12
Been looking at a few possibilities mostly Lunt and wondered if anyone has any recommendations?
something like
Lunt LS50THa Hydrogen-alpha Solar Telescope LS50THa/B600PT
with Sky-Watcher Solarquest solar go-to tracking mount and tripod
A lot of people have had success with a Quark which fits on the end of your own scope.  Might be worth asking Dave Taylor who comes to Cairds about it.
I can let you have his E mail address if you want to contact him.
yes i saw those , its an eyepiece for normal scopes , it needs to be plugged in to heat it up.
i was thinking a dedicated scope is more flexible, and standalone.
Thanks carole.
The Quark seems to be very versatile and producing some amazing images.  I would seriously consider it, particularly if you are just starting doing solar.
I have a double stacked SM60 set of Coronado etalons.  I bought these during the height of the previous solar maximum and used them extensively (see my Astrobin).   They show plenty of prominences, filaments, etc even during the current minimum.  There is still some time to go before the minimum is over but it may be a good time to start buying solar gear for the next maximum.
A dedicated scope is really dependent on the filters you buy for it.  Those can get really expensive as go up in aperture.
#4
Thanks for the advice , Roberto.
I have decided to go with the following
Lunt LS60THa/B1200CPT 60mm H-Alpha Telescope, Crayford Focuser, Pressure Tuner
ZWO ASI178MM USB3.0 Back-Illuminated Monochrome CMOS Camera with SONY STARVIS and Exmor R Technology
SkyWatcher SolarQuest Solar GOTO tracking Mount and Tripod with HelioFind Solar Alignment Technology
Tring Astronomy  gave smaller bundle discount and couldnt give a date on delivery, 365Astronomy gave a hefty discount and i can pick them up from them as i am close.
Sounds excellent Roger!  Looking forward to your images with the new kit soon!
Out of the box...
Just waiting for the Skywatcher Solarquest Tripod to come on tuesday,
That's excellent kit and a nice and compact scope ideal for the Solarquest - you won't be dissapointed with the results.  It's also a bit more flexible (tunable) than the Chromosphere though if you already have a longish focus refractor that option does work out a bit cheaper.  Of course the only bad thing is that it'll now be nice and cloudy for a fair bit, par with the course when getting new kit.
Enjoy.
PS. Good choice going with the B1200 rather than the cheaper B600.
Thanks Robert, yes i was advised to get the B1200 for better imaging,well we are just coming into Solar Cycle 25 so should get a few tips by then.
and on the solarquest mount,
now all i need is abit of sun to test it!
Roger :o
Cool!
Let's hope we get some sun between storms ...
Hugh
Wow Roger!  Looks a good set-up there.
Will look forward to some images in due course.
Best
Hugh
Quote from: Apophis on Feb 18, 2020, 16:53:49now all i need is abit of sun to test it!
That's a shiny piece of kit. Good luck with the Sun. ;)
thanks all,hopefully we are having a wet winter and a dry summer.
Very nice scope Roger!
Enjoy!
