Author Topic: Kemble 1 Asterism LRGB  (Read 436 times)
Apophis
  • Cluster Class
  • Solar , Deepsky
« on: Jul 18, 2019, 20:51:29 »
Something a bit different ,Kemble's Cascade (Kemble 1), located in the constellation Camelopardalis, is an asterism — a pattern created by unrelated stars. It is an apparent straight line of more than 20 colourful 5th to 10th magnitude stars over a distance of approximately five moon diameters, and the open cluster NGC 1502 can be found at one end.
It was named by Walter Scott Houston in honour of Father Lucian Kemble (1922–1999), a Franciscan friar and amateur astronomer who wrote a letter to Houston about the asterism, describing it as "a beautiful cascade of faint stars tumbling from the northwest down to the open cluster NGC 1502 that he had discovered while sweeping the sky with a pair of 7×35 binoculars.
Houston was so impressed that he wrote an article on the asterism that appeared in his Deep Sky Wonders column in the astronomy magazine Sky & Telescope in 1980, in which he named it Kemble's Cascade.
  • Star Class
Re: Kemble 1 Asterism LRGB
« Reply #1 on: Jul 19, 2019, 10:23:23 »
Nicely framed Roger
When did you take it?
Noel
    • Carole's images
« Reply #2 on: Jul 19, 2019, 10:54:05 »
As noel says, nicely framed.  I had heard of Kemble's cascade but not seen it before.
Apophis
  • Cluster Class
  • Solar , Deepsky
« Reply #3 on: Jul 19, 2019, 10:59:46 »
Thanks Carole and Noel, took it last Tuesday 16th,Moon was quite bright when it came above house,
Kelling Countdown..
    • Carole's images
« Reply #4 on: Jul 19, 2019, 11:52:54 »
Quote
Kelling Countdown..
Lol, you are funny.
You should start this in another thread.
