Moonview with Jupiter`s conjunction
Started by doug, Jul 17, 2019, 15:39:04
doug
     Another effort from me... took this with the Nikon at the same time as the conjunction.
Nice , if mankind was serious we should by now be able to see the large Moonbase complex that should have been there years ago,and probably have been to Mars and back by now,
Very good Doug
What lens did you use, or were you using a telescope?
Noel
