Sadr Region HaLRGB Reprocessed with HaGB
Started by ApophisAstros, Jul 11, 2019, 13:41:44
After a comment on Cloudy Nights i tried replacing Red channel with Ha.
EAGLE3, control unit for telescopes and astrophotography with ECCO dew control system.
Imaging telescope or lens:Altair Astro Lightwave 66ED-R refractor
Imaging camera:ZWO ASI183MM Monochrome 4/3" CMOS USB3.0 Deep Sky Imager Camera
Focal reducer:Skywatcher 0.85x Focal Reducer/Corrector for Evostar-120E
Software:Astro Photography Tool, Astroart 7.0 64bit , Registar 1.0.9 64bit.
Filters:ZWO CCD LRGB Filter-Set 36mm, zwo EFW 7-position Filter Wheel for 36mm Unmounted Filters,  Bhatinov Mask for DSLR & Telescope
Accessory:QHYCCD PoleMaster
Resolution: 5455x3781
Dates:July 1, 2019
Frames: 56x90 Ha , 40x90 LUM , 39x23RGB
Integration: 2.65 Hours
Locations: Home, Worthing, West Sussex, United Kingdom
Data source: Backyard
This is one you can add Ha to Roger, it's a good NB target just wait until you get your Oiii filter.
The LRGB has come out nicely but you have those green stars again.  Not sure how you are doing this.  Hopefully we can sort something out at the imaging session.
