IC 5146 Cocoon Dual Rig Combined Data
Started by ApophisAstros, Jul 05, 2019, 21:47:34
I combined data from Skywatcher 120ED DS-Pro with ZWO ASI178MM from 1/3/2018 , 13 x Lum @ 80s , 1.04 Hrs RGB with Altair Astro Lightwave 66ED-R and ZWO ASI178MM from 5/7/2019 , 22 x Ha @ 90s 16 x Lum @ 90s binning 1x1 , 5.75 mins of RGB binned 2x2 ,stacking done in Astroart 7.0 64bit then registering and cropping all to the luminance from 1/3/2018 in Registar 1.0.9 64bit then all joined together in Photoshop cs2.
Really good Roger
A lot of work to get that all working together, well done.
Noel
Well worth the effort and I bet there was a bit of a learning curve as well. Nice.
Not bad at all Roger.  A lot of work as said to combine, but it will get easier the more you do it.
Star colours and size are better than some of your recent images, but try not to burn out the core of the stars when stretching.  Do you move the white slider in Levels as this can cause this problem.  Only use the black and grey sliders.
Well done.
Quote from: Carole on Jul 09, 2019, 23:29:48
Well done.
No i never have moved that slider , but probably something else i do...
thanks Carole
