M33 Triangulum DSLR & CMOS combined
Started by ApophisAstros, Jun 14, 2019, 16:53:34
Stacked with Astroart 7.0 64bit
Registered , cropped and resized in Registar 1.09 64bit new Resolution 5414 x 3436
Processed in Photoshop CS2 v9
Astro Photography Tool
DSLR------------------------------------Canon 1000D modified
Resolution 3888 x 2592
40 Lights @ 300s 16oC - 20oC
Flat / Darks
24/07/2018
   CMOS------------------------------------ZWO ASI183MM Monochrome 4/3 CMOS USB3.0 Deep Sky Imager Camera
Resolution 5496 x 3672
60 Luminance @60s -10oC
33 Red           @60s -10oC
  9 Green         @60s -10oC
30 Blue          @60s -10oC
Darks / Flats
16/07/2018
Imaging telescope or lens:SkyWatcher 120ED Imaging System for Canon DSLR Cameras
Focal reducer:Skywatcher 0.85x Focal Reducer/Corrector for Evostar-120ED
Accessory:QHYCCD PoleMaster
Avg. Moon age: 23.31 days
Avg. Moon phase: 37.78%
Astrometry.net job: 2743679
RA center: 23.573 degrees
DEC center: 30.718 degrees
Pixel scale: 0.629 arcsec/pixel
Orientation: 89.747 degrees
Field radius: 0.560 degrees
Locations: DSC, Hastings, United Kingdom
Data source: Traveller
Excellent Roger!
That is very nicely processed and produced a result you should be proud of.
That's come out really well Roger.
Thanks Mark, another project trying it on all the images i have dual data for,
Well done Roger. you have  kept at it and it is paying off for you
