NGC7023 Iris Nebula CMOS Reprocess
Started by ApophisAstros, May 07, 2019, 16:43:07
Reprocessed from 29/09/2018 at Worthing using Astroart 7.0 64 bit instead of DSS also PS C2
Luminance x54 @ 180s
Red x19 @ 180s
Green x19 @ 180s
Blue 18 @ 180s
Flats and Darks
Technical card
camera ZWO ASI ASI183MM Pro (mono)
Scope SkyWatcher 120ED Imaging System
Mount Skywatcher EQ6-R PRO Synscan
Focal reducer:Skywatcher 0.85x Focal Reducer/Corrector for Evostar-120ED
Software:Astro Photography Tool,  ADOBE PHOTOSHOP CC,  Astroart 7.0 64bit
Accessories:QHYCCD PoleMaster,  Aurora Flatfield
Resolution: 3680x2500
Dates:Nov. 19, 2018
Frames: 110x180
Integration: 5.5 hours
Avg. Moon age: 10.94 days
Avg. Moon phase: 84.37%
Astrometry.net job: None
Locations: Home, Worthing, West Sussex, United Kingdom
Data source: Backyard
Looking a lot better than your original process Roger, but far too green.
Thanks Carole, Yes i forgot to use HLVG, so redone it.
Nice one Roger, a totally contracting image scale to mine.
That's definitely one of your best examples of processing.  The image is flipped i.e. it's a mirror image of the real thing.
Thanks , Mark and Duncan, should have mentioned cropped as well from original subs,
